Weird Oil Pressure Reading.
Old Jan 4, 2005 | 06:22 PM
Ls InTeGrA RaCeR's Avatar
Default Weird Oil Pressure Reading.
I just got an oil pressure gauge (brand new)hooked up on my Ls and its reading just about 20 psi at idle. What should it be reading because I know that it should be more than 20 psi. Is my oil pump to weak? If so what do I replace it with?
Old Jan 4, 2005 | 06:34 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Weird Oil Pressure Reading. (Ls InTeGrA RaCeR)
what does it read under wot?
Old Jan 4, 2005 | 06:36 PM
dornon13's Avatar
im pretty sure thats normal..my friend's reads that (on his ls)....but i would like to ask the same question for mine....i have a d16y8 and mine reads about 15psi.(idle) is that accurate its a brand new autometer electric gauge so i dunno i have just assumed its normal for now. i figured my vtec engine would have higher oil pressure than a non-vtec even tho its a soch instead of a dohc
Old Jan 4, 2005 | 06:38 PM
Slick GS-R's Avatar
Default Re: Weird Oil Pressure Reading. (dornon13)
20-30 psi at idle is normal ... you have to find out where it's at during WOT
Sohc Driver's Avatar
20psi is normal when the motor is warmed up and idling.
At WOT, the oil pressure should be at around 80psi.
Khoi
Old Jan 4, 2005 | 06:39 PM
93turbo16's Avatar
Default Re: Weird Oil Pressure Reading. (Slick GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver &raquo;</TD></TR><TR><TD CLASS="quote">20psi is normal when the motor is warmed up and idling.
Khoi</TD></TR></TABLE>
Old Jan 4, 2005 | 06:45 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Weird Oil Pressure Reading. (93turbo16)
mines around 75 on a b16
Old Jan 4, 2005 | 06:54 PM
Default Re: Weird Oil Pressure Reading. (wantboost)
when I'm driving around it reads around 70....so I guess that's not too bad right?
Old Jan 4, 2005 | 07:33 PM
Blackack26's Avatar
Hot idle is around 18-20 psi
WOT is about 65 psi (for the ls) Most likely higher for vtec motors
Old Jan 4, 2005 | 07:41 PM
m R g S r's Avatar
Well what does your cart idle at? When mine idles at like 300rpm's I only see 10psi lol
At 800rpm it is around 20psi.
The weight of the oil also plays a role in what pressure you will see. The temperature too, when it's cold, it will be higher.
Old Jan 4, 2005 | 07:56 PM
Default Re: Weird Oil Pressure Reading. (m R g S r)
idles at 700-800 rpm.
Old Jan 4, 2005 | 08:08 PM
wantboost's Avatar
Who is Mr Robot?
sounds normal, all motors vary due to clearances and oil choice
trulyshavedintegra
Dec 9, 2012 05:06 AM
ProjectBB6
Sep 16, 2009 02:18 PM
Rob97'SH
Feb 9, 2009 10:55 AM
hatchinprogress
Feb 15, 2006 04:57 PM
TurboCX
Aug 3, 2003 06:33 PM
