any one got experiance with these
Old Dec 31, 2004 | 04:19 PM
turbo gli's Avatar
Default any one got experiance with these
i need to run a -6 line from my stock tank. . only problem is its not a honda its a vw gti and it has a plastic tank
i am thinking of ways to eliminate the stock crap b/c its old and crap and rusting just worthless ..
figure i can leave the stock return line but for the feed to a inline walbro 255 i was thinking of "tapping " into the tank with one of these fuel cell bulkhead fittings .. [IMG] [/IMG] theres alot of plastic fuel cells that run these so i dont see how it would leak , as my stock tank is the same concept as thoes plastic cells just a diff shape ..
i could mount it in the lowest part of the tank
this way i dont haveto drop bank on installing a fuel cell properly / and i can still maintain alot of the stock stuff .. i.e filler neck , sending unit ext ..
anyone got experiance with bulkhead fittings ?
Old Dec 31, 2004 | 04:38 PM
evilone's Avatar
Default Re: any one got experiance with these (turbo gli)
in my experience they work well but i think you will have a real hard time finding the lowest point closest to the rear of that fuel tank that won't have road clearance issues. I don't know of any cheap safe way to sump a plastic tank. but you might want to look into using the factory pickup some how????
Old Dec 31, 2004 | 04:40 PM
turbo gli's Avatar
Default Re: any one got experiance with these (prostock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prostock &raquo;</TD></TR><TR><TD CLASS="quote">in my experience they work well but i think you will have a real hard time finding the lowest point closest to the rear of that fuel tank that won't have road clearance issues. I don't know of any cheap safe way to sump a plastic tank. but you might want to look into using the factory pickup some how????</TD></TR></TABLE>
i think ground clearance whont be a problem .. tank sits behind the rear beam and up into the body alittle .. one of thes with a 90 or 45 angle should work .. +++ im not going to be slammed ..
Old Dec 31, 2004 | 04:42 PM
MooreBoost's Avatar
Want do you need the stainless line for?
Old Dec 31, 2004 | 04:47 PM
turbo gli's Avatar
Default Re: any one got experiance with these (tegunderpressure)
not for bling .. my stock systme is pritty much rotted away .. its not even going to be stainless .. im gonna run some socketless fuel hose .. and i figure the monye spent on stock stuff .. might as well adapt it to what i need .. reson for this aswell is b/c the stock systmes on mk2 gti is all garbage .. its not like you honda guys .. but well not get into it .. and im runing standalone ..
Old Dec 31, 2004 | 05:01 PM
evilone's Avatar
than you still have the issue of the fuel sloshing around, normally in a sump or a stock tank you would have baffles. or you could just always have at least a 1/3 of a tank of gas at all times.(no hard turns under acceleration, especially with that solid rear axle,3 wheel motion )
Old Dec 31, 2004 | 05:13 PM
turbo gli's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prostock &raquo;</TD></TR><TR><TD CLASS="quote">than you still have the issue of the fuel sloshing around, normally in a sump or a stock tank you would have baffles. or you could just always have at least a 1/3 of a tank of gas at all times.(no hard turns under acceleration, especially with that solid rear axle,3 wheel motion )</TD></TR></TABLE>
true .. but i was also thinking .. runing the fitting threw the tank .. then a low pressure fule pump to feed a accumilator tank where the stock one was .. then from ther the walbro .. wala .. only think i wasnt shure of was the fitting leaking and what not ..
thanks
Old Dec 31, 2004 | 05:21 PM
evilone's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbo gli &raquo;</TD></TR><TR><TD CLASS="quote">
thanks </TD></TR></TABLE>
make sense, in my experiance they don't leak
jj07
Dec 27, 2007 09:18 PM
5thgencivic
Jan 9, 2006 09:28 PM
cjb80
Jul 2, 2004 08:07 AM
KStuned
Mar 17, 2004 09:20 AM
mister2racer
Feb 24, 2004 10:10 AM
