Cut out problem
Old Jan 5, 2011 | 08:36 AM
tundra2000's Avatar
Default Cut out problem
I bought my 94 hatch with a b20 swap turbo and the guy told me it was tuned and was pushing 12psi and this was my first turbo car so i didn't notice the psi on the boost gauge and when i was under the hood i accidently hit the boost controller which ended up turning it some so i thought i turned it back but when i go full throttle it will boosted then cut out so i turned it down some and now when i go full throttle it doesn't cut out and it reads about 7-8 psi, but i also notice when it boost it will go to about 8 psi then drop down some. So why can't i do more then 7-8 psi, do i need a aftermarket map sensor? or what? Sorry i don't know the exact type of turbo but all i know its a Mitsubishi turbocharger internal wastegate with about 55 trim.
Old Jan 5, 2011 | 07:24 PM
b16bri's Avatar
Default Re: Cut out problem
It was probually boost cut. When it was tuned they tuners set a boost limit if you will and when you try to go over that it dosent let you. providing the tuners set up a boost cut. If not it could be whats called breaking up eaither by fuel or spark. And when it jumps up to 8 psi and than back down it's probually boost creep/spikes. stock map sensors can read up to 10 or 11 psi i'm having a brain fart
Old Jan 6, 2011 | 09:32 AM
lsturbo33's Avatar
If your hitting boost cut it would feel like you hit a wall.
Old Jan 6, 2011 | 06:14 PM
tundra2000's Avatar
yeah when i go full throttle and it cuts out it feels like i pushed on the brakes then i let off some and it takes off, it only seems to do it when i go full throttle but if i'm slowly going full throttle it doesn't cut out.
h2b_sedan
Engine Management and Tuning
Nov 29, 2009 05:45 PM
user 98292739
Aug 10, 2006 07:49 PM
hondaimport99
Jul 30, 2005 07:17 AM
electric_rex
Sep 24, 2004 06:21 AM
0-60n4
May 22, 2002 08:12 AM
