Coating AND wrapping?
Old Jan 5, 2011 | 07:58 AM
Stopsign32v's Avatar
Loved
Default Coating AND wrapping?
Well we know keeping heat in = quicker spoiling and helps under hood temps. I was thinking of coating the manifold and downpipe I get and also wrapping it while putting a blanket on the turbo. Good idea? Anyone done this?
I'm surprised I've never seen a blanket on any builds here...
Old Jan 5, 2011 | 07:59 AM
TheShodan's Avatar
Moderator
Default Re: Coating AND wrapping?
Together both work extremely well. There's no real detriment to using both pieces.
Most people here just don't think about wrapping unless they feel they're experiencing heat problems.
Old Jan 5, 2011 | 08:15 AM
Glove's Avatar
I did this on my old manifold,
as long as you dont care about looks, it works amazing.
but once I took the wrap off, all the coating was chipped and flaked off, and kinda stuck to the wrap.
so if you ever wanna have the "coated" look afterwards, your gonna hafto get it coated again because the heat that gets trapped in by the wrap totally rapes the coating.
Old Jan 5, 2011 | 08:16 AM
Loved
I've always been a "every little bit counts" guy. So I'll be trying this. If anything to help with temps in summer with the half radiator.
Old Jan 5, 2011 | 08:17 AM
Loved
Now that's crappy news... Hmm
Old Jan 5, 2011 | 08:37 AM
Tootsie7944's Avatar
Coating doesnt cost that much...wrapping will reduce engine bay temps. I coated my full race manifold...it's starting to flake off and it's only been 2 years. The coating doesn't do a whole lot honestly.
Old Jan 5, 2011 | 09:11 AM
smoovy's Avatar
Ive used a couple Thermal Barrier Coatings from olycoatings.com. they worked great for me and kept the heat down. I dont know much about the spray can stuff as I dont think it holds up to the same temps...
Old Jan 5, 2011 | 09:27 AM
TheShodan's Avatar
Moderator
That depends upon the coating. From my experience and recollection, the right coatings shouldn't be affected by the wrapping; but it depends upon how it was applied.
Using a blanket and the turbine coating is fine. The case may be different with wrapping and the coating
Old Jan 5, 2011 | 11:18 AM
powerneedy's Avatar
You havent looked to hard as far as the whole wrap job as here is mine... but i guess it is in the road race section. the only thing coated on mine is the turbo housing everything else is stainless.
Old Jan 5, 2011 | 11:33 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
does your car have a block warmer?
Old Jan 5, 2011 | 11:36 AM
Mugencrxsir1's Avatar
I will be wrapping my ramhorn and putting a blanket on the turbo as my underhood temps are a little too high on my new set up. But in the past wrapping the header and downpipe made a big difference with my half radiator...
Old Jan 5, 2011 | 12:15 PM
TheShodan's Avatar
Moderator
Ooo. I love the new DEI wrap and turbine covers. Using those myself.
Old Jan 5, 2011 | 12:55 PM
Loved
Now THATS what I'm talking about!!!
Old Jan 5, 2011 | 06:03 PM
Sinople1's Avatar
theshodan im gonna send you my turbo manifold to wrap, damn yours looks good as hell!! haha
Old Jan 6, 2011 | 08:07 AM
powerneedy's Avatar
uhh hmm thats mine
Old Jan 6, 2011 | 08:39 AM
AlexDphoto's Avatar
how well do you find that works for you? any overheating problems when road racing? whats your cooling setup?
Old Jan 6, 2011 | 08:54 AM
powerneedy's Avatar
Here is the build thread https://honda-tech.com/forums/road-racing-autocross-time-attack-19/powerneedys-time-attack-build-2762721/
Just that wrapping and blanket alone runs much much cooler under hood temps. Everything around it isnt melting any more like the previous greddy setup... Oh and the best thing is my dip stick isnt ruined every time I come off the track lol.
Old Jan 6, 2011 | 09:10 AM
TheShodan's Avatar
Moderator
That's Powerneedy's, not mine.
Old Jan 6, 2011 | 09:14 AM
TheShodan's Avatar
Moderator
Are you referring to me?
My turbo setup for 2010-2011
Got rid of the HKS filter for an AEM Dry filter. Not as restrictive
I actually tapped the water lines to the wastegate, and thanks to B&R for the refiting of the turbo water lines. (Sorry for bad pic)
I'm sure Powerneedy is fine. I've found no overheating issues, using OEM coolant with Redline water wetter. The bigger issue is making sure that oil isn't overheating.
Old Jan 6, 2011 | 09:22 AM
AlexDphoto's Avatar
good call. I wanted to give my shot at road racing once this year just to have fun and gain experience.
My manifold is jet coated, but would you recommend wrapping it as well then? Ill be wrapping my down pipe and dumptube for sure, and a turbo blanket as well.
what kind of oil cooler setup do you guys have?
Old Jan 6, 2011 | 10:10 AM
Loved
Oh? I didn't know this was an issue. Would it still be an issue for a stock motor build?
BTW not wanting to take this thread off topic but could you give a quick overview of your new setup?
Old Jan 6, 2011 | 10:21 AM
AlexDphoto's Avatar
No its not an issue for a street strip car. What theyre referring to here is road racing and having the motor under stress for a great amount of time vs. 10-15 seconds at a time.
cdownin
Welding / Fabrication
11
Mar 19, 2010 03:14 PM
blackccoupe
Aug 31, 2007 02:45 PM
preveink
57
Jun 21, 2006 06:50 PM
huviduc
Nov 16, 2005 02:40 PM
Red99CivicSi
May 3, 2002 12:51 PM
