What size waste gate for my application?
Im in the process of a turbo build and i wasn't sure what size wastegate would be best for my application.
Setup:
b16a
2.5" intercooler piping
Synapse Ramhorn manifold
57trim turbo
750cc injectors
ect ect..
im planning on pushing about 10-14psi
Im going with tial just wasn't sure what size to go with 38m,40mm,44mm ect
please give input
Thanks in advance
Setup:
b16a
57trim turbo
750cc injectors
ect ect..
please give input
Thanks in advance
Re: What size waste gate for my application?
Alright, I just don't wanna drop money on a certain wastegate and then find out theres one that would work better in my setup.
A 1.6l with a 57trim will do just fine with a 38mm wg. It's when u have a big turbo and are trying to run low boost that a bigger wg is needed.
What power level are you looking to make? That number will determine the psi you will need in order to make said power. A Tial 38mm will be good.
Bringing this back to the top...
What about 3.0L displacement, with a TO4E 60mm, 60 trim - .63A/R? Running between 7-9 psi.
I was originally thinking a 38mm, but wondering if it will not be enough to control that little boost... Problem is 38 to 44 is a decent jump in price...This is for 1/2 of my engine - as it's a 6L v8...so I still have to buy (2) wastegates.
38mm is perfect for your set up!
Tial or Synapse...
I'm running Synapse for both my BOV and Wastegate and I love both!
Tial or Synapse...
