HEADGASKET!!!
Old Dec 31, 2010 | 06:17 PM
team_lunatics's Avatar
Default HEADGASKET!!!
I HAVE A F22B1. I BORED OUT THE BLOCK FROM 85MM TO 87MM. WAS WONDERING WHAT IS THE BEST HEADGASKET TO USE WITH THIS SETUP? ITS ALL STOCK WITH JUST RODS AND LOW COMPRESSION PISTONS, PLANNING ON BOOSTING TO GET AT LEAST 280+HP. OR CAN I JUST USE MY STOCK F22B1 HEADGASKET, EVEN IF THE BORE SIZE IS 85MM. ANY SUGGESTION? THANKS.
Old Dec 31, 2010 | 07:59 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
Default Re: HEADGASKET!!!
I would do a custom commetic. I had to on my all motor h2b that was 89mm due to the bore size.
Old Jan 1, 2011 | 07:12 AM
twkdCD595's Avatar
Dont bother with Cometic imo, when I tried to have one made they seemed less than interested in making one for the F22b1. Probably because it is such a small market.
Get an OEM bored gasket from Golden Eagle...
Old Jan 1, 2011 | 07:17 AM
thanks fella. i know for the f22b1 there is not much aftermarket parts for it. i will look into it. thanks fellas.
Old Jan 1, 2011 | 09:58 AM
Jimmynitro's Avatar
Check with bisimoto. He can pro. Get you one or modify one for your setup,,
Old Jan 1, 2011 | 10:37 AM
Bisimoto's Avatar
Yes, we have them in stock, coupled with any F22b parts you would need.
www.bisimoto.com/store
Old Jan 12, 2011 | 10:49 AM
Sales@Bisimoto.com's Avatar
Cant keep our headgaskets in stock! Get them while there here...
Old Jan 13, 2011 | 11:07 AM
reelg09's Avatar
Bisimoto Headgaskets work wonders... I've used them in all my builds.
Old Jan 13, 2011 | 02:42 PM
Janet@bisimoto's Avatar
We have head gaskets for all applications. Call us today to place your order.
Old Jan 13, 2011 | 07:16 PM
PyroProblem's Avatar
I have a feeling that Bisi and his team can help you out...
Old Jan 14, 2011 | 10:21 AM
twkdCD595's Avatar
Can you get them to a specified size bore besides whats listed on the website?
Bisimoto
Old Mar 2, 2011 | 02:18 PM
Head Gaskets! Head Gaskets! Head Gaskets!
If there is a specific bore size you are looking for, I can assist.
Old Mar 16, 2011 | 12:53 PM
Custom Head Gaskets In Production! Thank's Guys!
Old Apr 11, 2011 | 01:00 PM
Head Gaskets!
Old Apr 11, 2011 | 01:27 PM
extralargenog's Avatar
Ive Run OEMs as large as .5 MM bigger than stock bores, but at 89MM (2mm bigger than stock for the H) I ran a GE (bored out OEM) and the job that was done boring it was suspect. Cylinder bores were off center and actually touched the crush rings... I was less than impressed.
I had a MLS Cometic made for 89mm. Its ****. The construction and how clean the cylinder bores are over the GE modded one were noticable right off the bat.
Old Apr 11, 2011 | 02:16 PM
2k.civic.si's Avatar
Originally Posted by extralargenog
Ive Run OEMs as large as .5 MM bigger than stock bores, but at 89MM (2mm bigger than stock for the H) I ran a GE (bored out OEM) and the job that was done boring it was suspect. Cylinder bores were off center and actualy touched the crush rings... I weas less than immpressed.
cometic makes great headgaskets without breaking the bank.
Old Apr 11, 2011 | 03:30 PM
DelSolMarine's Avatar
golden eagle... or bisi... i learned the hard way with cometic...
Old Apr 11, 2011 | 03:38 PM
GE is OEM (so they say). Mine (GE) was garbage (Not the gasket itself... but the modification was sloppy and lent to fail).. Non MLS Cometic (the composite ones) I wouldnt touch.
The stamped MLS Cometic is 10 times nicer than a bored GE . Ive had both.
Im making over 750 WHP on a MLS Cometic. Its butter, as I mentioned NOTABLY nicer than a hacked GE OEM.
Old Apr 11, 2011 | 08:01 PM
bigsnorlax's Avatar
definitely look into the cometic as nog stated or the bisi one. Iv heard a ton of good things about bisi's but cometic is the go to source for that kind of thing BECAUSE they are very good.
Are you on stock sleeves? I'd be a bit worried going that large on stock sleeves.
btech
Sep 2, 2006 09:08 AM
turbotime
Nov 7, 2005 04:20 AM
hatchblack
Oct 18, 2004 06:40 PM
X-Mazda 3 Racer
Aug 2, 2004 08:58 AM
GSR_Hacker
Oct 7, 2002 12:47 PM
