oversized valves?
Old Jan 15, 2011 | 02:22 PM
2kdrift's Avatar
Default oversized valves?
ok guys been searchin but cant really get a good answer for this
my current build is a mini me
d16y7 block (stock) / d16 z6 head in a del sol with a garret t25
i recently ported the head and i am considering doing bigger sized valves. would this add noticeable power? also considering the springs with a bigger cam but at this point i really like the idea of bigger valves i like the drive ability of the stock cam.
Old Jan 16, 2011 | 06:28 AM
Turbo-LS's Avatar
Default Re: oversized valves?
leave the stock size valves especially when going larger cam.
Old Jan 16, 2011 | 10:27 AM
rev-speed's Avatar
a bigger cam will wake that motor up
u will feel a big difference on responce
and idle stock with a good tune.......
Old Jan 16, 2011 | 10:32 AM
guy_from_nerk's Avatar
Whats your power goals? Thats going to determine if or if not you need an aftermarket cam shaft.
Old Jan 16, 2011 | 12:58 PM
LSVTECEF91's Avatar
if you go with biGG cams and over size valves they WILL hit eachother...
Old Jan 16, 2011 | 04:38 PM
CO_RaceFab's Avatar
^is this guy serious?^
Old Jan 16, 2011 | 09:51 PM
rev-speed's Avatar
lol
Old Jan 17, 2011 | 08:05 AM
sethm's Avatar
wow
Old Jan 17, 2011 | 12:27 PM
LSVTECEF91's Avatar
my brother inlaw had one on his crx and he threw the S2 pros and guess what $$$ out the door...so you can try it but the set up was on a B series not sure about your D's
unless you pull your timming cause bigger cams, vavles will also push and lift higher they will meet
MORE INFO IF U NEED IT THIS IS FOR A (B)
http://www.b20vtec.com/forums/all-mo...pros-cons.html
FOR A (D)
.u kno u dont really have to do any massive port n polishing u kno...u could just clean up wat the manifacture gave u..as a matter of fact u dont even have to port the intake side.Just port the exhaust...Reason being the intake coming into the head isnt really as important bcuz the air coming into the head is being forced into the head by the turbo...getting air out is more important...the better the air flows out the faster turbo spools n more efficient the turbo is.....As far as the clearance issue goes...its better to do a clearance fit before starting the motor...
Old Jan 17, 2011 | 02:21 PM
b20vtech's Avatar
If your not looking for the very last HP the engine can make then forget about head porting & oversize valve. a stock head can make crazy HP in a FI application. Now if it was a NA engine, head porting and sometimes bigger valves will see good gains.
Old Feb 17, 2011 | 10:38 PM
ek4serge's Avatar
but if it was a NA engine with a head porting and bigger valves are you sure thats a good idea ?"VTEC motors dont react well to oversize valves. Like was said before, when you are using big N/A cams or even turbo cams, you will have a clearince problem. There is more of a risk, than a comfortable gain, when using OS valves"
remoer
Dec 6, 2007 06:22 AM
91redteg
10
Oct 16, 2007 09:38 AM
GarageAlchemist
Oct 7, 2006 08:11 AM
Renegade
May 17, 2004 03:50 PM
Layziebtnh055
May 15, 2004 09:51 AM
