turbo
Old Dec 27, 2010 | 03:50 PM
detour94civic's Avatar
Icon2 turbo
what is the best turbo setup for a ls b18 out there?
Old Dec 27, 2010 | 03:53 PM
grumblemarc's Avatar
The Grumpiest
Default Re: turbo
Please do some research before you ask such a question. Check the Forced Induction forum. Read. Read. Read.
Old Dec 27, 2010 | 04:39 PM
SOHConthis's Avatar
Default Re: turbo
t3t4 kit at like 8-10 psi.
Old Dec 27, 2010 | 04:40 PM
The Grumpiest
Default Re: turbo
Here we go...
Old Dec 27, 2010 | 04:50 PM
NotAJDMFanBoy's Avatar
Default Re: turbo
Read up on how different trims and aspect ratios as well as different size turbos (T3, T04E, "T3/T4" hybrid, T04B, 14B, etc) are going to behave. Maybe a little tiny DSM would be best for you, maybe a big T04B will. Journal bearing or dual ball bearing?
Research different manifold designs. A cast log type will behave different than a top mount and the prices vary a LOT. About $200-2000
Tuning? Chrome, Hondata or AEM EMS?
Full on build with forged pistons and sleeved block, add some ARP rod bolts and head studs, or just keep it all stock?
Running 91 Octane, E85, or C16 race gas and methanol injection?
Can you run stock ignition system, or have to upgrade to an expensive MSD setup?
Until you understand the differences in all of these, just wait. You'll just kick yourself for buying something you don't need or want or won't benefit your project. You can start by determining your HP goal. From there you can figure out the rest. Adding 15 hp more will be a lot different than adding 500 hp.
Old Dec 27, 2010 | 05:10 PM
The Grumpiest
Default Re: turbo
2 questions only. Power goals? Budget?
Old Dec 27, 2010 | 05:37 PM
jonesEK's Avatar
Default Re: turbo
IBTL
Old Dec 28, 2010 | 09:45 AM
Schister66's Avatar
Man U FTW
Default Re: turbo
The best turbo kit for your LS is whichever turbo kit (either bought as a whole or assembled in pieces) that fits your goals and budget. To figure out which setup works best for you, start in the FAQ at the top of the Forced Induction forum. Read and learn, then you will be able to make an informed decision.
airwalk07143
Sep 19, 2009 09:10 AM
egmatt93
May 1, 2008 04:54 PM
Yani
Nov 21, 2005 06:49 PM
AaronJ
Oct 13, 2005 11:51 AM
1fstevo
Nov 18, 2001 01:07 AM
