pipe size on top mount
Old Dec 30, 2010 | 02:11 AM
bzyq2001's Avatar
Default pipe size on top mount
ok guys,
i'm planning to build top mount manifold for my 9:1, 84mm b18 with divided t4 gt35r on pro1 cams and i'm thinkig what size pipe diameter do i need - 40,42,45,48mm ? (inner);
and one more- i want do only one WG, can i do it on long tube, that will connect right before WG? will that make some kind of peeks in TQ or something ?
Old Dec 30, 2010 | 11:03 PM
bzyq2001's Avatar
Default Re: pipes size on top mount?
nobody?
Old Dec 31, 2010 | 03:05 AM
SARswimmer's Avatar
Default Re: pipe size on top mount
what size wg to you plan on running? and i would plan on having the wg right at the collector where all four tubes converge... try to ensure the tubes are the same length as to equal out the distribution of gas out of the cylinders
Old Jan 1, 2011 | 12:34 PM
bzyq2001's Avatar
if i do one WG i plan to go with 44mm
Old Jan 2, 2011 | 10:18 AM
bzyq2001's Avatar
can somebody messure it or know what he own ?
Old Jan 3, 2011 | 01:34 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
you should have this moved to the welding fabrication section as you will get alot more feedback.
Old Jan 3, 2011 | 02:42 AM
bzyq2001's Avatar
ok, THX, i'll do that
Danronian
Welding / Fabrication
38
Feb 16, 2010 03:20 AM
anton_
Feb 23, 2008 02:04 AM
Inextricabledrvr
Jun 3, 2004 10:24 AM
NINJASPY
Apr 29, 2004 04:24 PM
