Killed a 30r ..Why ?
Old Dec 22, 2010 | 11:09 AM
DUKE LADUKE's Avatar
Default Killed a 30r ..Why ?
So I just killed my 30r and I am wondering if this would of done it . I picked uip one of those cheap catchcans on ebay for the hell of it . I hooked up one line going to the black box on the motor . Then another going to the valve cover . With my new turbo on it started automatically pushing oil through the turbo compressor as well as in the exhaust . Smoke was everywhere. When I unhooked the black box line everything stoped and went away . Could this of blown my other turbo from running it like that all summer. I didnt have an issue with smoke like I am but I wonder if too much pressure built up in the can. There is no breather for the can to vent as well . I am retarded and it was probably something stupid.
Also the can did not overfill .. has only drained about 1/4 since june iunto the can .
Old Dec 22, 2010 | 11:41 AM
TiAL's Avatar
Default Re: Killed a 30r ..Why ?
how did you kill the turbo with excessive oil pressure?
Old Dec 22, 2010 | 11:42 AM
rat city rex's Avatar
Sell me your 30r
Old Dec 22, 2010 | 12:21 PM
TheRappist's Avatar
How did you kill the turbo? I am lost?
Old Dec 22, 2010 | 01:19 PM
Originally Posted by rat city rex
Sell me your 30r
sold it already !
I thought it would be because of the pressure or something like that due to the can other then that no idea. Oil psi is fine, restrictor is fine. I bought it used and put about 7k on it before it needed a new center cartridge
Old Dec 22, 2010 | 01:27 PM
TheShodan's Avatar
Moderator
so what was the point of this thread again?
Old Dec 22, 2010 | 02:01 PM
Can that way hooking up a catch can cause a turbo to blow..
Old Dec 22, 2010 | 03:56 PM
eg:R's Avatar
No, I think your turbo is still ok and a catch can can't cause a turbo to blow. You should have check your drain
Old Dec 22, 2010 | 04:05 PM
TheShodan's Avatar
Moderator
The catch can hook up MAY cause the oil drain to back up, but again... MAY. I wouldn't hook it up that way, however.
Old Dec 22, 2010 | 04:41 PM
golf-mk3's Avatar
I think your oil seal going has nothing to do with the breather setup. on a side note i think u would of been better off removing the black box and using the blocked off breather ports in the back of the block.
Old Dec 22, 2010 | 06:42 PM
IDK why your turbo took a ****, but I will tell you that your ringlands are gona take a **** with your sealed catch can. You would be better off unhooking the catch can and just running the line form the back of the black box to free air. Same thing with the port on your valve cover.
Old Dec 22, 2010 | 07:37 PM
Yea just unhooking the can .
G-Auto*Hero
Jun 4, 2009 07:26 PM
hondaluver12
Apr 18, 2009 08:05 AM
crxt25turbo
Apr 16, 2008 08:25 AM
boostedcoupe1
Feb 20, 2008 01:55 PM
datspeed77
Jan 8, 2002 10:40 PM
