AC friendly manifold options
Old Jan 15, 2011 | 07:20 PM
$amGD3's Avatar
Swaggylicious
Default AC friendly manifold options
Hey everyone, 'tis the season of tax return coming up and I'm doing as much research as I can for my boosting options.
OTHER than the greddy kit, BLOX and the inlineFOUR manifold, what are my other options for AC friendly manifolds?
This will be on an EM1 with the B16a2 btw
Thanks!
edit, just found out about Blox
Old Jan 16, 2011 | 03:28 AM
markymark885's Avatar
Default Re: AC friendly manifold options
Im doing the same reasearch, theres also ,Love Fab and
Full-race -EG B Series ProStreet AC Turbo Manifold $1299(out of my Price range)
Old Jan 16, 2011 | 05:35 AM
TakumiJr's Avatar
Synapse Turbo also makes a nice a/c and p/s ramhorn manifold for a good price ($750)
http://www.synapseturbo.com/mm5/merc...turbomanifolds
Old Jan 16, 2011 | 06:10 AM
Turbo-LS's Avatar
the em1 has more room so it should be easier to fit. but yeah the cast logs or the SPA cast top mount or an a/c friendly tubular unit wil al work with some minor modifications
Old Jan 16, 2011 | 09:25 AM
$amGD3's Avatar
Swaggylicious
Cool beans. For the cast logs I mentioned above, what brand/ size turbo am I limited to?
Basically, if I cant find a used greddy kit. I was planning on piecing it together with the blox mani and finding a used Mitsu 18G turbo. Possible?
Old Jan 16, 2011 | 03:03 PM
Turbo-LS's Avatar
you are basicaly limited to a t3/t4 with an E cover, possibly some severe block grinding might ft an S cover. biggest turbo ive seen is a sc6152e capable of 600+ or the spa cast you can definatly run a t3/t4 s cover. also your limited to the ford 5bolt turbine housing on the cast logs
Old Jan 17, 2011 | 06:05 AM
Woody.'s Avatar
Love fab mini ram is a nice unit. Lifetime warrenty too.
Old Jan 17, 2011 | 07:46 AM
NotAJDMFanBoy's Avatar
Sometimes what they sell as one thing isn't exactly what it is. I know my two Turbonetics have a 20192 compressor housing and it's sold as a T04E usually, but if you look it up, it's a T04B.
Old Jan 17, 2011 | 09:04 AM
sethm's Avatar
im in the same boat.. not going without a/c again
Old Jan 17, 2011 | 09:14 PM
JdmTypeRdc2's Avatar
SLS makes a great manifold...Great quality and construction. They are my favorite along with PFAB.
Old Jan 18, 2011 | 04:01 AM
Turbo-LS's Avatar
Im in a DC chassi with a/c and p/s only thing i had to do was run a half sized radiator and bend my lines a little bit. running a spa top mount with 3" dp and a garrett E cover t3/t4
Old Mar 25, 2011 | 02:25 PM
precisionsc54's Avatar
so u didnt have to use the clocking flange for it to fit? Any pics of your setup?
Old Mar 25, 2011 | 02:31 PM
reboosted's Avatar
if u do keep your ac, wrap your lines. i learned the hard way
Old Mar 25, 2011 | 02:32 PM
2xraeted's Avatar
do you have a pic with the SPA top mount in the dc chassis
Old Mar 25, 2011 | 02:45 PM
samuraijackass's Avatar
I have an unused drag manifold and DP that's A/C friendly. if you want it I will sell it cheap.
Old Mar 25, 2011 | 05:27 PM
ttt
Old Mar 27, 2011 | 04:48 PM
bump keep it going for more info
Old Mar 28, 2011 | 11:26 AM
DelSolMarine's Avatar
something to be especially aware of with these AC ramhorn manifold is the impractical location of the wastegates placement. while the full-race version has a slightly better design do to the curved inlet to the wastegates elbow, rather than the gasses having to take a direct 90 degree turn, its still difficult to control boost creep because of the wastegates placement. I highly recommend from personal experience that anyone running a turbo the size of a T3-60-1 of large to run the vbanded 44mm wastegate.
I will be customing my creepboost AC manifold with a 2.5 inch elbow with a 60mm tial wastegate recirculating back into the exhaust in july. I am in california for training currently. I will post pictures of this and give feedback.
I want to be able to run 7psi in 1st and 2nd gear with recirculating...
Old Mar 28, 2011 | 12:20 PM
racebum's Avatar
since i can't find a size chart anywhere online, how big of a physical difference is there between a B and E cover?
Old Mar 28, 2011 | 12:44 PM
turbohatch96y7's Avatar
Since this is up.. Im trying to make my hf manifold work on my hx and keep my ac with a 14b is there enough room for the turbo? Or do I need a adapter plate?
Old Mar 30, 2011 | 05:16 PM
bump
Old Mar 31, 2011 | 03:06 PM
Turbo-LS's Avatar
Sorry yes i used the clocking flange in my car. its a must for better fitment. Heres a pic
Old Mar 31, 2011 | 03:22 PM
did u have to cut the radiator support? no other options?
CD5_530
Apr 30, 2009 10:03 PM
DelSolMarine
Jan 21, 2007 12:52 PM
sQwiReL bOi
Mar 23, 2004 07:20 PM
fernancivic
Aug 5, 2003 01:49 PM
