need help getting oem head gasket
Old Dec 27, 2010 | 09:42 AM
young geezer's Avatar
Default need help getting oem head gasket
ok so i have ls block thats bored 40 over and i ve been trying to buy some oem headgasket that 82mm. i ve called the dealeership and they said they only sell the original size. so can someone help me direct me to the right place to buy oem ls headgasket thats is 82 mm? thanks.
Old Dec 27, 2010 | 10:27 AM
mike93eh2's Avatar
Default Re: need help getting oem head gasket
http://www.goldeneaglemfg.com/index....roducts_id=553
Old Dec 27, 2010 | 10:45 AM
thanks but golden eagle is my second option. another question is, is non vtec and vtec use the same headgasket, cuz the link provides a vtec headgasket.
Old Dec 27, 2010 | 01:54 PM
guy_from_nerk's Avatar
Golden eagle is OEM headgaskets, bored out....they are your only option if your wanting OEM. I have a cometic on my GSR and haven't had any issues
Old Dec 27, 2010 | 08:37 PM
so ls and gsr block use the same headgasket?
Old Dec 27, 2010 | 09:57 PM
CO_RaceFab's Avatar
^no they dont... golden eagle should be your first and imo your only option
Old Dec 28, 2010 | 08:47 AM
a1320addict's Avatar
OEM Honda headgasket is good from 81-82mm. Golden Eagle MFG offers an "82mm", but I can guarantee you it is untouched.
Old Dec 28, 2010 | 09:11 AM
This too, I have heard that an OEM 81mm headgasket will work on a 82mm bore
Old Dec 28, 2010 | 09:12 AM
well i am little confuse because on the golden eagle link above says it fits on any b series block. can someone else explain this for me before i buy that headgasket.
Old Dec 28, 2010 | 02:51 PM
CO_RaceFab's Avatar
On the factory ones the dowel pins holes are different.... golden eagle sells a custom dowel pin set for the vtec gasket on an ls block.
wanabecurry
Feb 21, 2014 11:59 AM
young geezer
Dec 16, 2010 09:04 PM
ls_bitik
Jul 9, 2007 08:54 AM
Turboteggy
Mar 12, 2004 12:16 PM
SpoolnG2
Oct 28, 2003 07:30 PM
