Internal vs External Wastegate
Old Jan 3, 2011 | 04:23 PM
98tegLSvtec's Avatar
Default Internal vs External Wastegate
Howdie Folks was wondering is and internal wastegate any good?
Old Jan 3, 2011 | 05:01 PM
Default Re: Internal vs External Wastegate
Was considering this turbo:
http://cgi.ebay.com/ebaymotors/Godsp...Q5fAccessories
Old Jan 3, 2011 | 05:17 PM
darkvader0's Avatar
I don't know about that turbocharger, but internal wastegate in itself is fine if you don't have really high power goals.
Old Jan 4, 2011 | 03:23 PM
By high power goals your talking over 350whp, if so then no 350whp max prolly
Old Jan 4, 2011 | 06:54 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
lol. higher power goals have nothing to do with whether a internal waste gate will work for you or not. just think of it like this, the lest boost you run the more work your wastegate has to do because its letting out more exhaust gas to keep the turbo at said boost. the higher the boost you run the less work your w.g. is doing. guys run 42lbs of boost with a evo 9 turbo with a single flapper internal w.g. its when you try to run a 35r on a 2.0l at 5 lbs your gonna have problems.
Old Jan 4, 2011 | 10:21 PM
Garage 808 Hatch's Avatar
the guys running 42lbs on evo turbos arent even using the WG at that point. Its all that pea shooter can produce.
Old Jan 5, 2011 | 11:29 AM
Loved
Community Favorite
ya exactly. its just saying that the internal w.g. doesn't really matter when you crank the boost up alot.
Old Jan 7, 2011 | 12:57 PM
Arighty so you think its smarter to use internal wg
Old Jan 7, 2011 | 02:25 PM
B18CivicEJ8's Avatar
It's not smarter or dumber to use an internal or external WG. It just depends on how you want to setup your car.
http://www.turbobygarrett.com/turbob...o_tech101.html
Go down to the wastegate section and read up. I run a Tial 44mm external WG that vents to the atmosphere (open loop). It's a costlier setup cause a Tial WG isn't cheap and you'd need a manifold that accommodates an external wastegate (which isn't hard to find). It's just how you prefer to setup your car. If you are in a state that is strict on emissions, running an open dump tube would be illegal, so an internal wastegate setup would be more emissions friendly or you could route the dump tube back into the exhaust further down (closed loop).
Old Jan 7, 2011 | 05:17 PM
By smarter i mean,
Internal waste gate recirculates the exhaust as apose to the external wastegate that releases the exhaust into the air.
But by having an internal wastegate does it put extra pressure on the turbo?
Old Jan 8, 2011 | 12:02 AM
sethm's Avatar
How much boost are you trying to run
Old Jan 8, 2011 | 11:01 AM
96_charcoal_tsi's Avatar
Not all external wastegates dump exhaust intothe air. You can still route the dumptube back into the exhaust to keep noise to a minimum.
Old Jan 8, 2011 | 02:14 PM
What ever it takes me to hit 350 whp with a 9:1 compression motor
This is true but i think im gonna run a stainless downpipe and to reweld that would suck!
grand champ
Jan 14, 2010 02:51 PM
bsmith100
Nov 30, 2008 08:27 PM
93hatched_projekt
Nov 23, 2005 12:31 AM
fkneh
Oct 11, 2005 03:55 AM
meanteg
Dec 4, 2001 06:27 AM
