boosted stock b18b1
Old Jan 8, 2011 | 11:15 AM
EGcivic_95's Avatar
Default boosted stock b18b1
hey well im planing on putting a turbo on my stock ls motor, but having some problems with money. so i have a list of what i have now, and i want you guys to tell me things i am missing that i absolutely have to have or it wont run.
-turbo
-manifold
-3' exhaust
-piping+intercooler
-oil feed lines
-boost controller
-blow off valve
-wastegate
-dump tube
-down pipe
-injectors
so i know im missing a few maybe if i am please let me know what is a need to have. Thank you.
Old Jan 8, 2011 | 12:00 PM
EGcivic_95's Avatar
Default Re: boosted stock b18b1
anyone??
Old Jan 8, 2011 | 12:17 PM
slostjoe's Avatar
-turbo
-manifold
-3' exhaust
-piping+intercooler
-oil feed lines
-boost controller
-blow off valve
-wastegate
-dump tube
-down pipe
-injectors
Wideband, boost gauge, some sort of tuning software and and oil drain line and that should get it running
Old Jan 8, 2011 | 12:38 PM
EGcivic_95's Avatar
oka thank you
Old Jan 8, 2011 | 12:43 PM
EGcivic_95's Avatar
What is the wideband ment for? is it a need to have for it to run?
Old Jan 8, 2011 | 12:45 PM
Stopsign32v's Avatar
Loved
Tuning. Have someone tune your car and you don't need the wideband unless you want to keep check of your AFR to make sure it doesn't lean out on you because of bad gas or other things. Not a bad thing to have IF it has an alarm or you watch it regularly.
Old Jan 8, 2011 | 12:50 PM
sanman000719's Avatar
wide band isnt needed man your tuner will use his to tune you out
Old Jan 8, 2011 | 04:07 PM
Omegax10's Avatar
x2 especially on the gauges They can save your car if something ever goes wrong. You could also if there isnt a tuner around you get a basemap loaded on your ecu by either xenocron or phearable to get you to the tuner and get the car running. I used xenocron on my b18a1 and it ran perfectly fine very rich.
Old Jan 8, 2011 | 04:11 PM
EGcivic_95's Avatar
Ok ill get a wideband lol but thanks a lot guys,
Old Jan 8, 2011 | 05:48 PM
BLU CIVIC's Avatar
Track Advocate
-don't need a boost controller, just get the proper size waste spring.
-don't think you need a 3" exhaust since you're turboing a stock LS.
-need to add fuel pump
-since you're saying you're having money problems, i'd skip the wideband for now
-i'd possibly opt for a tunerview instead of a boost controler
Old Jan 9, 2011 | 01:31 AM
sethm's Avatar
what are you going to use to tune
Old Jan 15, 2011 | 06:09 PM
EGcivic_95's Avatar
hmmm, neptune or hondata
poorhonda
21
Mar 7, 2008 05:47 AM
haitech
Dec 16, 2004 11:26 AM
JonGP4
Dec 29, 2003 08:44 AM
turbod16y8
Mar 23, 2003 04:44 PM
clean
Aug 14, 2002 06:22 PM
