fuel pressure regulator vac for bov???
Hi guys, im trying to tap a vac to my bov, and i was wondering if it is possible to use the source from the fuel pressure regulator. Thanks guys.
Re: fuel pressure regulator vac for bov???
I was wonderin about hookin my boost gauge there. Everyone I talked to recommended me to use a diff source and don't T into that line. For my bov I used the nipple runnin from the nipple the used to run to my evap canister
I tried running my boost gauge there but it wasn't reading. I was using the nylon line. I'm going to try to use a rubber one tomorrow. That source isn't a good vac. For bov- bov not too responsive. I've read that some ppl has ran the gauge there and it works. Hope that helps.
update: Fuel pressure vac is fine for boost gauge source. I'm not sure if it is too effective for bov though.
