removing wrist pin ?
Old Dec 31, 2010 | 09:39 AM
bnmm's Avatar
Default removing wrist pin ?
can i just get a wrist pin puller tool and do so or does a machine shop have something special to do it...i have a press also...what about puttin tem in?
Old Dec 31, 2010 | 10:27 AM
RACEPAK's Avatar
Default Re: removing wrist pin ?
let a shop do it, you may need to preheat is before removing it,
Old Jan 1, 2011 | 09:08 AM
EG1834's Avatar
A shop is going to have to do it, especially if you want to slavage the pistons afterwards. They'll use a press, but they should have a special fixture to support the piston squarely and have a piloted mandrel to press the pin out of the bore squarely so that it doesn't mess up the bore.
Old Jan 1, 2011 | 09:55 AM
Jimmynitro's Avatar
Def need to heat the rod,,, you can do it yourself just b carefull. But machine shop would be preferred.
GSR-C5
Oct 31, 2007 12:29 PM
b18bEKcoupe
Jul 4, 2007 07:11 AM
SaM DA Man
Dec 16, 2006 07:15 PM
94-integra-ls
Feb 5, 2006 01:09 PM
RHDintegXsi
Mar 12, 2005 12:38 AM
