Where to get eclipse turbo?
Old Jan 10, 2011 | 10:51 PM
Jdmdelsolb16a's Avatar
Default Where to get eclipse turbo?
Hey guys im just wondering where i can get a cheap eclipse turbo off a dsm or whatever they call those eclipses lol havent really looked into eclipses but ya im wondering about how much boost i could run on them if put on a stock d16z6
Old Jan 10, 2011 | 11:23 PM
sethm's Avatar
Default Re: Where to get eclipse turbo?
T25 or the 14b? You can search on the classifieds or some of the dsm forums, ebay, or craigslist. I found this tool that makes searching cl a lot easier searchtempest.com hope that helps
Old Jan 10, 2011 | 11:30 PM
30psi_gst's Avatar
Ive got 2 T25s laying in my garage.
Old Jan 10, 2011 | 11:45 PM
sethm's Avatar
Made that search easy. If your not looking at building the block those turbos will work fine on a budget build.
Old Jan 11, 2011 | 10:05 AM
TheShodan's Avatar
Moderator
you could also check on DSM Tuners . com . they can be found for $25-$50
Old Jan 11, 2011 | 03:28 PM
whats better t25 or 14b? i think its the t25 im gonna get and i hear you have to weld on a downpipe with these eclipse turbos is that true? is it because the turbo doesnt line up with i think the t3/t4 flanges?
Old Jan 11, 2011 | 03:30 PM
how much and in what shape are they? any chips or anything did they leak or smoke when they were taken
Old Jan 11, 2011 | 06:03 PM
TheShodan's Avatar
Moderator
The T25 from an eclipse still uses a radius flange and not the rectangular T25 that you're used to seeing. you have to use the Mitsubishi O2 housing that they come with, and bolt a 2 bolt exhaust flange to match to it. You'll need to use a T3 to Radius flange adapter to do this. This is why it is such a pain in the *** to do, because you get almost no benefit from it.. even if running "a couple of psi"
Go to the DSM forums, they'll get either one to you. The only reason why they even sell those is because something is wrong with them and they're waiting for someone like you to think that it can be repaired "on the cheap" to use later. In this situationThere is no better between a 14b and a T25 because they are all bad.
Old Jan 12, 2011 | 12:50 PM
O alright thanks man would I be better off with an eBay turbo then the eclipse turbos....I hear good and bad stuff bout eBay turbos all the time people say they work fine and other people say they are shitty and not worth it
Old Jan 12, 2011 | 02:10 PM
TheShodan's Avatar
Moderator
Umm actually NO. Actually you'd be better off with an OEM factory turbo than Ebay garbage. you'd have NO power with one application vs going NO WHERE with the other.
Get real equipment and quit playing games.
Old Jan 12, 2011 | 06:36 PM
eh but when your on a budget you gotta play games sorry i dont have $500+ to spend on just the turbo i still need other stuff to run a turbo...
accord478
Aug 19, 2007 03:08 PM
b_rad
Oct 23, 2005 12:21 PM
Nytmair
Oct 23, 2005 11:41 AM
EJ1 wilcox
Apr 22, 2004 08:02 AM
SickRevHrdTeg
Aug 18, 2002 02:19 PM
