About pauter rods - edm?
Old Jan 2, 2011 | 09:43 AM
PARADOX_sf's Avatar
Default About pauter rods - edm?
Hi.
When do i need EDM pressure-fed oiling to pin on pauter rods?
Thank you!
Old Jan 2, 2011 | 10:23 AM
smoovy's Avatar
Default Re: About pauter rods - edm?
I currently use pauter rods and I did not get this option. there are several rod manufacturers who do not offer this option so I don't know how important this is. honda engines are oil pressure happy and there is no need to "pressure feed" the wrist pins because there is plenty of oil getting to them already..
Pressure fed oil to the piston pins is only required for engines running high levels of crankcase vacuum. In the engines with low crankcase vacuum it is possible to starve the pins of lubrication.
Totally not required for normal applications.
Old Jan 3, 2011 | 03:54 PM
PARADOX_sf's Avatar
How much is high vacum?
Keo00civic
May 14, 2014 04:56 PM
boomslang
May 26, 2012 08:50 AM
ralph11sec
May 24, 2008 08:26 PM
EKB18BPR3
Oct 30, 2004 09:30 AM
mrx
Jun 26, 2004 01:39 PM
