Boosting b16....
Old Dec 28, 2010 | 10:48 AM
hotdoggies's Avatar
Default Boosting b16....
Hey guys i just recently came back into the honda scene. I have purchased a 99 civic si bone stock with 130000 miles on it. Possibly wanting to boost it. Will this be ok or will the motor need to be freshened up? compression test was low 200's across the board. Im not looking for Internet hero dyno numbers.....looking for 250 whp maybe a lil morecas it needs to be reliable. Please chime in with expierience or info., Thank you
Old Dec 28, 2010 | 01:33 PM
da_dude's Avatar
Default Re: Boosting b16....
If the compression are good then you should be fine. Just make sure you get it tune.
Old Dec 28, 2010 | 01:51 PM
hotdoggies's Avatar
Would the rods be fatigued from high miles?
Old Dec 28, 2010 | 04:04 PM
ZLboosted_EG's Avatar
Those truely aren't high miles if it's been maintained. If comp is good (within specs) then just slap a kit on, tune it then enjoy
Old Dec 28, 2010 | 04:19 PM
Ls_dx's Avatar
B16 with a 28R or 30R = super fun
Old Dec 28, 2010 | 04:45 PM
Rage Cayman's Avatar
[QUOTE=ZLboosted_EG;44310200]Those truely aren't high miles if it's been maintained. If comp is good (within specs) then just slap a kit on, tune it then enjoy[/QUOTJust place a good turbo kit on it. I did 7.5 in the 1/8 mile with a bone stock B16a with 140xxx mile on it.
Old Dec 28, 2010 | 05:36 PM
tonythetuner®'s Avatar
Yea 250 is reliable for that motor with that many miles just get a GOOD TUNE . I would put a new head gasket and arp studs thow. Cuz your gonna need head studs for that much hp. And a new head gaket won't hurt or you can do one head stud at a time if you don't want to do a new head gasket just make sure you replace them in the right order one by one I did it the one by one method. Motor runs fine no headgasket problems. Many don't recamend it. But been running 200 hp on a b16 now for 4 months no problems yet. Gonna be getting a bigger turbo and injectors soon and a retune gonna be shooting for 300hp
Old Dec 28, 2010 | 05:50 PM
importeclipsegst's Avatar
Well I had my 2000 civic Si wth a bonestock motor/head with a greddy kit on 8 psi, it put down 221hp and 181Tq for over 2 years tuned on a crappy V-AFC, took off turbo kit 3 years ago and my motor has 210 psi across the board. Still runs strong!
Old Dec 28, 2010 | 06:55 PM
K7-1Ktrevor's Avatar
Loved
Community Favorite
you wont need arp headstuds for 250whp lol. as long as your not detonating in boost you shouldn't have any issues with blowing a h.g. what so ever. if you are detonating in boost you need a different tuner.
Old Dec 29, 2010 | 12:06 AM
rev-speed's Avatar
stock b16 with gt40= street king
https://honda-tech.com/forums/forced-induction-16/so-sad-our-oem-b16-bottom-test-motor-hurt-i-guess-470-too-much-i-guess-lol-2871767/
Old Dec 29, 2010 | 05:35 AM
blackeg's Avatar
dont even bother putting a 40r on your stock b16. also, lets clear the myth that you need a gt series turbo.
match the turbo to your motor, power goals, transmission and working rpm range. not much of that turns into "slap a huge turbo on a little motor and have 2000 rpms powerband on a street car"
over the summer i tuned 2 turbo b16's. one had a 60-1 on it running 9 psi. the other had a 57 trim also on 9 psi. let me tell you the 57 trim was much much nicer to drive around. more area under the curve, better response and just all around more fun.
Old Dec 29, 2010 | 11:08 AM
rev-speed's Avatar
your jokeing rite
a b16 with a 40r reving to 10k has way more then 2k rpm of powerband..............
Old Dec 29, 2010 | 11:12 AM
hotdoggies's Avatar
I think a 40r rev-speed woud be over kill for me. I think you would have more than 2k rpm worth of powerband though....I was looking into a 28r what kinda numbers am i looking at with this setup? Also iam going to use a iron manifold i absolutely have to keep a/c. P/s is not a concern. Im more concerned with spool and curve. I just think 250whp is a nice compromise..
Old Dec 29, 2010 | 12:55 PM
rev-speed's Avatar
if u want a small turbo
get a used 3076
u can t go wrong
spools super fast and can make 600whp!
brent_si
Apr 16, 2007 12:22 PM
94hatchvx
Nov 5, 2006 09:34 PM
civictildeath
Aug 2, 2006 09:46 PM
RedRacer
May 20, 2005 03:24 PM
Garbonzon311
Jan 26, 2004 10:54 PM
