2 maps on E85
Old Dec 27, 2010 | 05:27 PM
civic-r11's Avatar
Default 2 maps on E85
I am wanting to run e85 for race gas.. and then want to run just pump 93 when i don't have e85 to run.. is this possible on s300?
Old Dec 27, 2010 | 07:11 PM
V-SPEC 1's Avatar
Default Re: 2 maps on E85
yes.
Old Dec 28, 2010 | 08:07 AM
boosted94gsr's Avatar
Yep my car has a switch wired to the dash that switches s300 from a pump gas map to a race gas map.
Old Dec 28, 2010 | 09:32 AM
Schister66's Avatar
Man U FTW
Even Crome can manage this...if you're willing to open the ECU and swap chips; nevertheless, its possible
Old Dec 28, 2010 | 02:50 PM
swappedcx's Avatar
I was wondering this exact same thing with regards to e85 and pump. Glad this thread showed up.
Old Dec 28, 2010 | 05:28 PM
civic-r11's Avatar
Oh really.. I was wondering about how I could switch it.. how did u wire it.. I'm curious so I could have a idea on how to do it.. I was not going to fully have e85. On it meaning.. like at a qtr of a tank fill it up with e85.. cause i never let my gas go down all the way to empty..
Old Dec 28, 2010 | 09:10 PM
SovXietday's Avatar
That is a BAD idea.
There is a BIG difference in fuel consumption between gasoline and ethanol. If you start mixing gas and E85 you are going to change your ethanol to gas ratios and you're going to get really nasty fluctuation in your AFRs and instability with your engine being able to ward off detonation, especially if you mix E85 with a quarter tank of gas and then try to run the E85 map. You will be rich as hell and probably detonating everywhere.
If you're going to run different setups between gas and E85, you need to have as little left as possible when switching to the other fuel type.
Old Dec 29, 2010 | 07:09 AM
civic-r11's Avatar
Originally Posted by SovXietday
That is a BAD idea.
Ok cool.. I am just not trying to run race gas.. and e85.., is good stuff.. so basically when the gas light comes on.. then I could switch gases? Lol... is there a better option/ way of getting best of both worlds?
Old Dec 29, 2010 | 07:14 AM
kyden's Avatar
i suppose you could use a fuel sensor, but it just seems like a waste of effort to me. its not really a big deal imo to drain the tank and put whatever fuel you wanted to in there.
Old Dec 29, 2010 | 07:21 AM
Spawne32's Avatar
http://www.moates.net/font-size-12ti....html?cPath=69
Old Dec 29, 2010 | 07:28 AM
mtber's Avatar
s300 has dual mapping built into it, your tuner will be able to take care of this for you :-)
Old Dec 29, 2010 | 07:54 AM
lsturbo33's Avatar
I have a few different tunes that are saved on my laptop. All I do is upload the file to the ecu to switch to a different tune. The hardest part about it is booting up the laptop. lol.
Old Dec 29, 2010 | 11:02 AM
civic-r11's Avatar
Damn.. it's that hard.. LOL.. cool..
Old Dec 29, 2010 | 12:23 PM
civic-r11's Avatar
I'm hoping I can make good power with this e85.. on a built 2.0liter gsr.. my 60-1 hifi is going to kill me.. wish i could geta a better turbo..LOL
turbo-crx
Nov 26, 2008 11:39 AM
boostincoupe
Dec 13, 2007 09:20 AM
b18_racer805
Apr 14, 2007 08:26 PM
spoolingb20
Aug 21, 2006 10:21 PM
Nextelbuddy
May 5, 2004 10:53 PM
