wastegate problem on b18
Old Jan 1, 2011 | 08:18 PM
HondacivDX's Avatar
Default wastegate problem on b18
got a 95 civic with a b18 swap and got a problem with the external wastegate...its opening up at idle and i had a 10lb spring in it and put a 15 in after and it still open. i also try andadjust the manual boost controller and doesnt seem to help. anyone got and suggestions
Old Jan 1, 2011 | 08:38 PM
HondacivDX's Avatar
Default Re: wastegate problem on b18
its a tial 38mm
Old Jan 1, 2011 | 08:40 PM
ryguy2588's Avatar
Could be a vacuum line being hooked up to the wrong thing, or maybe you don't have a firing ring for your wastegate and that could be leaking the exhaust right through your wastegate.
Old Jan 1, 2011 | 08:44 PM
ryguy2588's Avatar
Idk if you have seen this or if you got it with your wastegate, but did you hook it up like this?
http://www.tialmedia.com/documents/w..._wginstall.pdf
Old Jan 1, 2011 | 10:04 PM
blwn95civic's Avatar
You should have the top port vented to the atmosphere and the side port connected to a vaccume source.
Old Jan 1, 2011 | 10:13 PM
HondacivDX's Avatar
i have a line running from the nipple off the turbo to a "T" and running one of the t to the side port and the end to a mbc the to the top port is that wrong???
Old Jan 1, 2011 | 10:21 PM
Yupp thats wrong... Run the vaccume source from your "T" to the boost controller. Then from the boost controller to the side port on the wastegate. Leaving the top port to be vented to the atmosphere. Good look on putting the vaccume source before the throttle body.
Old Jan 1, 2011 | 10:27 PM
HondacivDX's Avatar
so really just eliminate that "T" run vacuum to the mbc then to the side port
Old Jan 1, 2011 | 10:33 PM
Yes sir... then boost away!
Old Jan 1, 2011 | 10:36 PM
HondacivDX's Avatar
ok thanks for the help really apprciate it
turbo se
Jun 13, 2003 11:33 AM
accordfreak
Mar 2, 2003 10:28 AM
blu_si
Oct 1, 2002 04:20 PM
B18C4-T
Jun 29, 2002 01:14 PM
boosted hybrid
Mar 1, 2002 05:44 AM
