Peak and hold injectors?
Old Jan 10, 2011 | 11:37 AM
BoostinTEG's Avatar
Default Peak and hold injectors?
I'm looking into getting some larger peak and hold injectors for my b16a, Its already has some dsm 450cc's installed in it.
I'm looking at 750cc RC injectors and at the 680cc precisions.
The only thing is i heard that RC injectors sometimes have fitment issues?
I'm going to be pushing between 10-15lbs of boost on my setup off a 57trim.
What would you guys recommend I get?
Old Jan 10, 2011 | 11:44 AM
AlexDphoto's Avatar
Default Re: Peak and hold injectors?
fic, go saturated, 1000cc injectors here idle like stock. no need for a resistor box either.
Old Jan 10, 2011 | 12:04 PM
TheShodan's Avatar
Moderator
Since you have the resistor box in already, no need to remove it. I'd personally use a Precision Injector at about 880cc or so, and call it a day. You would have to retune the car to account for the new duty cycle and time delay for the injectors.
Old Jan 10, 2011 | 12:11 PM
AlexDphoto's Avatar
thats true ^^
I have never heard of RC's with fitment issues though.
Old Jan 10, 2011 | 05:41 PM
BoostinTEG's Avatar
while I was searching earlier, I read that If you go over 800cc's while using a resistor box The idle will become really choppy and you wont see the true potential of the injector unless you run injector drivers.. Is that true? or does somebody just not know what they're talking about?
Old Jan 10, 2011 | 06:01 PM
Mugencrxsir1's Avatar
Yep I have 880cc injectors from Precision and love them! Stock idle here!
Old Jan 10, 2011 | 06:03 PM
I'm doing just fine in my crx with my Precision 880's, they idle like stock! Nothing more than my resistor box!
Old Jan 11, 2011 | 03:32 AM
BoostinTEG's Avatar
alright sweet, is there either a vendor or a website that you would recommend to get them from?
Old Jan 11, 2011 | 08:02 AM
BoostinTEG's Avatar
^ disregard last question. I found a local shop nearby that sells them. So should i just go with 880cc's or would it be better to go with 780ccs? would their be any difference in tuneability, or how good they idle?
Old Jan 11, 2011 | 08:40 AM
TheShodan's Avatar
Moderator
880cc is fine and easier to replace. no difference in 10cc of "tuning".
Old Jan 21, 2011 | 03:22 PM
BoostinTEG's Avatar
Alright so i got the injectors, and the bottom of them fit fine into the intake manifold.. but the o-rings on the top wont fit and are alot larger than stock. I could probably force them in but that seems like a bad idea. Ive tried lubing them up and they still get pinched when i apply force to them. What should i do??
Old Jan 21, 2011 | 03:27 PM
You need to post a picture of your fuel rail... And is your fuel rail OEM or aftermarket? And if OEM, is it Gen 1 or Gen 2?
Mine fit just fine with my gen 1 b16 fuel rail, but I do remember them being nice a snug!
Old Jan 21, 2011 | 03:28 PM
BoostinTEG's Avatar
its an aftermarket one, think its AEM but not sure. Ill post a pic in a few.
Old Jan 21, 2011 | 03:41 PM
BoostinTEG's Avatar
The dsm injectors i had inbefore slipped right in with a little force. These ones on the other hand have huge o rings on them.
Old Jan 21, 2011 | 04:38 PM
dpetro1's Avatar
get some oem honda fuel rail o-rings. they arent as fat as the one that come with precision and rc.
honda part# 91301-P2F-A01
Old Jan 21, 2011 | 05:42 PM
TheShodan's Avatar
Moderator
Those are the honda ones from Precision, correct? they use a smaller hat and o-ring
Old Jan 21, 2011 | 06:20 PM
I remember my o-rings being black and not green... I wonder if they changed there supplier with will cause obviously fitment issues! Yeah try the stock OEM o-rings...
Old Jan 21, 2011 | 06:34 PM
BoostinTEG's Avatar
Yes they are the Honda peak and holds from precision. But the o-rings pinch when you try and push them into the rail. They fit fine in the manifold.
So i should just go and buy the oem honda o-rings?
Im just afraid if i push on the rings too hard they might get nicks or splits..
Old Jan 21, 2011 | 06:42 PM
TheShodan's Avatar
Moderator
Try the oem o-rings
Old Jan 22, 2011 | 06:34 AM
BoostinTEG's Avatar
Alright im gonna give them a shot, I gotta go to the dealership to get manifold studs anyways so ill order some o-rings while im at it.
GT500FTW
Nov 29, 2012 03:10 PM
b16bri
Sep 5, 2010 02:53 PM
nolicense526
Jul 31, 2007 06:17 AM
swt_666
May 16, 2007 09:33 PM
Schister66
Apr 26, 2006 08:36 AM
