Ls/Vtec sandwich plate and turbo feed line
Old 01-03-2011, 10:14 AM
Lewy. Dee Ayy's Avatar
Default Ls/Vtec sandwich plate and turbo feed line
Anyone run there turbo feed line off golden eagles sandwich plate from there ls/vtec kit?
or is it just best to run it the old school way off the oil pressure sensor?
Also if its ok to run it off the sandwich plate are the threads on those extra ports on the plate the same thread as the OEM oil pressure sensor? Just need to know if any honda feed line will work or do i need a custom thread pitch line to make it work..
Thanks for any input. i did a quick search and didnt come up with much. we all know the search on this site can be useless.
Old 01-03-2011, 10:20 AM
mtber's Avatar
Default Re: Ls/Vtec sandwich plate and turbo feed line
I have ran my feed line off a sandwich plate before without issues.
You will need to configure the ports on the sandwich plate to accept a 3 an fitting for your feed line etc. (Assuming your using a 3 an feed line).
Old 01-03-2011, 11:09 AM
Mattb16teg's Avatar
Running my feed line off my MFactory sandwich plate. My sandwich plate came with npt to an fittings, which pretty much made it "plug and play"
Old 01-03-2011, 09:44 PM
civickiller's Avatar
I was running my lsvtec and turbo feed lines from my sandwich plate
Ash J. Williams
11-08-2012 08:16 AM
krazeenoy
02-22-2008 09:31 PM
projectwidow
05-22-2007 01:47 PM
a1320addict
03-21-2006 09:13 PM
Casey
08-13-2004 09:10 PM
Quick Reply: Ls/Vtec sandwich plate and turbo feed line
