Remove ball plugs (crank)
Old Oct 12, 2006 | 01:15 PM
lsturbo9's Avatar
Default Remove ball plugs (crank)
IS IT A GOOD IDEA TO REMOVE THE ball plugs FROM THE CRANK ?
Old Oct 12, 2006 | 01:19 PM
lsturbo9's Avatar
Default Re: Remove ball plugs (lsturbo9)
BUMP
Old Oct 12, 2006 | 01:56 PM
abnaasefmb's Avatar
they are there for a reason
Old Oct 12, 2006 | 03:05 PM
Runnerdown's Avatar
Default Re: Remove ball plugs (abnaasefmb)
If you remove them correctly and tap and plug the hole then its the best way to properly clean a crank. I would recommend you let someone who has done this work before try, unless you have a spare to practice on first.
Old Oct 12, 2006 | 03:30 PM
B18C Turbo's Avatar
just had ABT machine do mine. Remove press in ball plugs, clean the crank, tap it and bag it. $100.
Old Oct 13, 2006 | 06:46 AM
lsturbo9's Avatar
THANKS FOR THE INFO
pleej
Sep 10, 2009 02:03 PM
NJIN BUILDR
13
Jan 30, 2007 08:15 AM
boostnubII
Nov 8, 2006 10:25 AM
DB1_559
21
May 9, 2006 07:02 PM
Na-Spirit
Apr 10, 2005 05:22 PM
