Need help, installing kit, oil feed problems
Old Oct 13, 2006 | 04:58 PM
Civicman86's Avatar
Default Need help, installing kit, oil feed problems
Im installing a kit for a friend. Im using Fast Turbo oil feeds and T3/T4 turbo. The fitting that comes with the Fast turbo kit is thread brass fitting. The instructions say to screw the brass fitting into the turbo oil inlet. Problem is the oil feed is not threaded. What can I do? I guess I could thread the turbo but I wouldnt think I would have to do this.
TIA
Old Oct 13, 2006 | 05:40 PM
Civicman86's Avatar
Not only does the oil not have a tap, the peice they have to put in the block for the oil feed does not fit in the hole. Im really getting angry with this ****. I dont think the oil return is going to work either.
Old Oct 13, 2006 | 06:10 PM
coneheadsracing's Avatar
Default Re: Need help, installing kit, oil feed problems (Civicman86)
I'm confused. The turbo you have does not have any threads? What does it look like then. You sure you've got the inlet and not the out let?
What fitting do you have for the block? Probably need a bspt to npt adapter, 1/8th inch, and then should be able to screw the line into it. I don't know, need more info, pictures are great
Old Oct 13, 2006 | 06:13 PM
ghettochild's Avatar
Default Re: Need help, installing kit, oil feed problems (coneheadsracing)
yes pics would be great
Old Oct 13, 2006 | 07:17 PM
Civicman86's Avatar
Default Re: Need help, installing kit, oil feed problems (ghettochild)
The L shaped peice I drew is this part:
That is suppose to screw into the inlet on the turbo but the inlet is not tapped. Its just a straight through hole.
It looks like I need this part that Full Race offers (middle hole threaded)
My pic:
Problem is that its not my car and I wanted to get it done by this weekend. IM not very happy with the fast turbo parts right now. On my civic I had problem with the oil return lines and now IM having problems with the feed and return on this kit. (The peice that is suppose to go into the block, its threads are jacked up and wont go in).
I need to find a way to get this done by the weekend. Otherwise I dont know what to do.
Old Oct 14, 2006 | 06:18 AM
Civicman86's Avatar
ttt
Old Oct 14, 2006 | 06:46 AM
nuttybumpo's Avatar
Default Re: (Civicman86)
just skip the inlet flange the brass l will fit onto the turbo
Old Oct 14, 2006 | 06:47 AM
shortyz21's Avatar
get a piece of steel. and make one.
Old Oct 14, 2006 | 08:31 AM
NoahJob's Avatar
That's weird that there are no threads on the oil inlet. what kind of turbo is it?
Old Oct 14, 2006 | 09:26 AM
Civicman86's Avatar
Default Re: (NoahJob)
t3/t4
And yes it is wierd that its not threaded.
Modified by Civicman86 at 10:43 AM 10/14/2006
Old Oct 14, 2006 | 09:35 AM
stealthmode62's Avatar
You're going to need a 1/8 npt tap. It's like $12 at the auto parts stores. Tap it upside down so no metal shavings get down into the turbo.
It's very common for the block to have old sealer on the threads for the oil pressure sensor. That could be the reason the block fitting doesn't seem to want to go in.
Old Oct 14, 2006 | 09:45 AM
Civicman86's Avatar
Default Re: (stealthmode62)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealthmode62 &raquo;</TD></TR><TR><TD CLASS="quote"> You're going to need a 1/8 npt tap. It's like $12 at the auto parts stores. Tap it upside down so no metal shavings get down into the turbo.
It's very common for the block to have old sealer on the threads for the oil pressure sensor. That could be the reason the block fitting doesn't seem to want to go in. </TD></TR></TABLE>
Yeah not only that but the moron who put his motor in used RTV on EVERYTHING including the oil send unit. Not just a little, like bottles.
Thanks for the help. Im going to leave it up to him wether he wants me to tap it, or wants to order the flange.
Old Oct 14, 2006 | 12:18 PM
Mag00n's Avatar
Some turbos need an inlet flange as well as the return flange
they are like 5-20bucks depending on who you get it from
MantisX
Sep 14, 2007 06:36 AM
mike93boost
Jun 25, 2006 04:32 PM
thaiphob
Dec 30, 2003 09:30 AM
nonvtec
Sep 8, 2003 12:03 PM
Elite Hatch
Oct 20, 2002 05:43 AM
