Wideband/Narrowband with the innovate LC-1?
I was wondering exactly what you do for narrowband tuning on the LC-1?
I know the yellow wire is for wideband tuning.
Do you just hook up the brown wire and then you will be able to?
Maybe a switch between the brown and yellow wire hooking it up to pin D14?
Just makin sure, if I am wrong then correct me.
Re: Wideband/Narrowband with the innovate LC-1? (HickamHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HickamHatch »</TD></TR><TR><TD CLASS="quote">I was wondering exactly what you do for narrowband tuning on the LC-1?
Just makin sure, if I am wrong then correct me. </TD></TR></TABLE>
A switch sounds like a good idea! but I think you will have to change the settings to 'closed loop' for the ecu to start using narrowband signal.
It's all in the manual:
http://www.innovatemotorsports...l.pdf
epicbeats
07-29-2009 12:59 PM
GuitarSlinger78
Audio / Security / Video
09-12-2004 08:16 AM
