Adjust Fuel Pressure for nitrous?
Old Oct 11, 2006 | 09:58 PM
JDMDC4life's Avatar
Default Adjust Fuel Pressure for nitrous?
I recently installed a Zex nitrous kit on my Integra ls and I plan to run a 65 shot. I also have a FPR and I was wondering if I should adjust it now that im running nitrous. My fuel pressure currently reads 40 psi at idle and gos up to around 45psi when I push the gas pedal.
Should I adjust it?
If so what should my fuel pressure be at?
Old Oct 11, 2006 | 10:28 PM
JDMDC4life's Avatar
Default Re: Adjust Fuel Pressure for nitrous? (moops vs moors)
yeah but its a dry kit...
even so i know zex dry kits monitor nitrous bottle pressure and add or subtract enrichment fuel so the engine never runs too rich or too lean when using nitrous.
Old Oct 12, 2006 | 02:18 PM
Attaus's Avatar
Just installed a ZEX 55 shot on my H23.. no problems yet. All I did was install 2 step colder plugs. If you're really worried about it retard your timing a degree. Changing the plugs is most important.. I wouldn't run even the 55 without atleast one step colder plugs.
Fuel upgrades aren't really necessary with this kit. They're a safeguard, but more than likely you'll be getting enough fuel.
95greenlude
May 2, 2007 02:02 PM
avividmemory
May 28, 2003 11:32 AM
hondaeg5
Nov 28, 2002 12:09 AM
itr--779
Jul 27, 2001 02:17 PM
