boosted h22 overheating
Old Oct 11, 2006 | 03:02 PM
eggie75's Avatar
Default boosted h22 overheating
ok. before, the car used to overheat when the a/c was on. i thought maybe the turbo was too close to the rad / fans / condensor and everything was getting heat soaked. so i replaced the radiator and fan setup and it gave me about an inch more room. Great! a thicker radiator and a couple of high cfm fans + more room. now the car overheats anytime at a stand still. no probs when driving. i've already replaced the fan switch and thermo to mugen about 10k ago. water pump was done about 10k ago w/ t belt. i decided to add one more fan pushing in front of the condensor where the turbo is. the car still overheats, but only up to about the 3/4 mark. if at a stand still and i rev the motor, i can see the needle start to go down. i decided to bleed the coolant... nothing. nothing comes out. i can take the bleeder bolt all the way out, and nothing. there's plenty of coolant in both rad and overflow. both hoses are hot. is it the thermo?
Old Oct 12, 2006 | 03:25 AM
eggie75's Avatar
anyone?
Old Oct 12, 2006 | 06:50 AM
PrecisionH23a's Avatar
Default Re: boosted h22 overheating (eggie75)
Sounds to me like the headgasket is shot. A tell tale sign is the overflow tank will overflow when you are boosting.
Also, ditch that mugen thermo and replace it with an OEM one.
Old Oct 12, 2006 | 07:22 AM
teamlegacy's Avatar
Default Re: boosted h22 overheating (PrecisionH23a)
Replace the thermostat and rebleed the system. Also check the ground wires on the tranmission and underneath the thermostat housing. Make sure what temperature the computer is reading, don't always rely on the gauges.
I had a similar problem where the gauge would read hot, but Crome read normal and if I accelerated the gauge would go to normal then back up. It was a missing ground wire.
Old Oct 12, 2006 | 01:11 PM
ragethemachine86's Avatar
Default Re: boosted h22 overheating (teamlegacy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamlegacy &raquo;</TD></TR><TR><TD CLASS="quote">Replace the thermostat and rebleed the system. Also check the ground wires on the tranmission and underneath the thermostat housing. Make sure what temperature the computer is reading, don't always rely on the gauges.
I had a similar problem where the gauge would read hot, but Crome read normal and if I accelerated the gauge would go to normal then back up. It was a missing ground wire.</TD></TR></TABLE>
interesting, unlikely tho considering the car wont even start with either of those grounds not hooked up as mine did.
Old Oct 12, 2006 | 01:20 PM
teamlegacy's Avatar
Default Re: boosted h22 overheating (ragethemachine86)
When mine wasn't connected it started and ran fine. Weird?
Old Oct 12, 2006 | 04:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamlegacy &raquo;</TD></TR><TR><TD CLASS="quote">When mine wasn't connected it started and ran fine. Weird?</TD></TR></TABLE>
lol i guess. a missing ground and throw alot of things out of whack (my car wouldnt start at all) but i guess it differs from car to car.
Old Oct 12, 2006 | 07:16 PM
Antilag's Avatar
Try water wetter and water and shimming your hood up to help the hot air escape easier.
Old Oct 12, 2006 | 07:26 PM
HamiltonRex's Avatar
Default Re: boosted h22 overheating (9sech22civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9sech22civic &raquo;</TD></TR><TR><TD CLASS="quote">Try water wetter and water and shimming your hood up to help the hot air escape easier.</TD></TR></TABLE>
yup hood idea is good. BTW, its a cowl induction, it brings in cool air, dosent expel air.
Old Oct 14, 2006 | 04:47 AM
eggie75's Avatar
hmmm... thanks. will check grounds.
Old Oct 14, 2006 | 05:37 AM
fastludeh22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9sech22civic &raquo;</TD></TR><TR><TD CLASS="quote">Try water wetter and water...</TD></TR></TABLE>
i always use that.
also as far as grounds go...they make a big difference. i dont have any of the factory ones, so when i put this new engine in, i grounded the tranny w/0 gage wire, which is huge, and another 8 gage on the starter. thought that would be enough. well car started and ran fine, but the gage was reading hot! changed everything and no luck. did a compression test and was perfect...added a 8 gage ground to the thurmo housing, and a 8 gauge to the valve cover and hasnt read hot since!!! mine was the 3rd case in a few weeks that thought we were overheating and it was bad grounds in the prelude forum...
Old Oct 14, 2006 | 06:40 AM
shortyz21's Avatar
Default Re: boosted h22 overheating (fastludeh22)
headgasket..
Old Oct 14, 2006 | 07:59 AM
Default Re: boosted h22 overheating (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">headgasket.. </TD></TR></TABLE>
well he needs to check if water is in his oil...and do a compression test...honestly i was starting to think that was my problem before i tried the grounds
Old Oct 14, 2006 | 08:09 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">
well he needs to check if water is in his oil...and do a compression test...honestly i was starting to think that was my problem before i tried the grounds</TD></TR></TABLE>
I've had a few cars that yielded great compression results but yet had toasted headgaskets. Both of these cars did not have oil in the coolant either.
Old Oct 14, 2006 | 08:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">
I've had a few cars that yielded great compression results but yet had toasted headgaskets. Both of these cars did not have oil in the coolant either.</TD></TR></TABLE>
your not making me fell better! lol, jk well i hope all is good for him then. my prob was fixed with grounds, hope yours is something simple...
Old Oct 15, 2006 | 07:40 AM
shortyz21's Avatar
yeah my car did this, thought it was the HG but nope.
i put a new headgasket on my car last weekend. same ****. i was ttold a cracked head somewhere, so i got another head and imma put it on this week..
coolant issues suck!
Old Oct 15, 2006 | 09:13 AM
Penny's Avatar
good luck. i had the same issues till i replaced the head. i didn't have oil in the coolant and i tried changing the hg too. i have a h23 if that makes a difference.
Old Oct 21, 2006 | 06:46 AM
eggie75's Avatar
overheating has been pretty random. like every other day. changed fan relay. has not overheated in 2 days. keeping fingers crossed. coolant is clean. will change oil to check oil. hope its not hg.motor was built about 8k ago. never revved past 6k. been at 7lbs. since. only started overheating recently.
supermotothud
Dec 19, 2008 01:38 AM
twenty
Jul 21, 2005 04:32 PM
coupon
Jul 21, 2005 10:42 AM
twenty
Jul 21, 2005 08:36 AM
Morhpeous
Apr 26, 2004 06:39 PM
