went to the dyno problem though please help
Old Oct 8, 2006 | 11:10 AM
exotik4doorcivic's Avatar
Default went to the dyno problem though please help
went to the dyno low #'s and seems like vtec not working
d16z6 in a dx civic
14b turbo
tuned with chrome pro currently 8 lbs
450 cc injectors
full msd ignition (cap wires coil)
ngk v power gapped at .28
2.5 inch piping thermal exhaust gutted cat
act 12 lb flywheel/stage 2 clutch/pp
i only got 165 whp and 140 tq wtf??
the question is my speedometer only works sometimes not all the time and it wasnt working at the dyno pull, and ive heard if your speedometer does not work then niether does your vtec
also i hooked up a vtec led and (power went to solenoid green/yellow and groungd went to 330 ohm resister then to ground)
the led does not come on????
any help is appreciated
Old Oct 8, 2006 | 12:03 PM
Jared's Avatar
without a vss input the vtec will not activate
Old Oct 8, 2006 | 12:16 PM
B18 CYA's Avatar
yup, tach not working, then vtec won't work
Old Oct 8, 2006 | 12:18 PM
Default Re: (B18 CYA)
tach works but not speedo
Old Oct 8, 2006 | 12:49 PM
B18 CYA's Avatar
meant to say speedo since that signal comes from your vss. if you have an electrical vss check to make sure its plugged in, and if its mechanical check to make sure the cable is all the way in
Old Oct 8, 2006 | 02:03 PM
sc4dr's Avatar
I always here people say vtec wont work if vss isnt working, but I've had vss problems before, and it never affected vtec actuation. Would this depend on what ems is being used?
Old Oct 8, 2006 | 02:05 PM
Boner_Ben's Avatar
Default Re: (sc4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">I always here people say vtec wont work if vss isnt working, but I've had vss problems before, and it never affected vtec actuation. Would this depend on what ems is being used?</TD></TR></TABLE>
Yes, with different ems you can control the parameters for vtec to engage.
Old Oct 8, 2006 | 02:06 PM
ATYPR's Avatar
Default Re: (sc4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote"> Would this depend on what ems is being used?</TD></TR></TABLE>
yep
Old Oct 9, 2006 | 06:03 AM
boosted k20's Avatar
Default Re: (FUCATYPR)
in crome check the box in the options menu where it says "disable VTEC speed check"
Old Oct 9, 2006 | 07:34 AM
Default Re: (boosted k20)
ok thanks i will do that
Old Oct 10, 2006 | 11:41 AM
Lude_H22A1's Avatar
I have a 1993 Honda Prelude Vtec
This same problem happened to me today.
I was normally driving and then my speedometer went out. Then later on I noticed my vtec wasnt kicking in.
As I read above, it is my vss input that is the problem.
Could someone please inform me what a vss input is and where it is located.
Thanks
Old Oct 10, 2006 | 01:36 PM
THEDirtyDseriesWOOT's Avatar
yah disable speed check in crome... if u aren't going anywhere on the speedo it wont engage.. in neutral stoped it wont work but if u are rolling it will ...Disable it and u will hear the brilliant angelic call of vtec mmm so good
Old Oct 10, 2006 | 08:47 PM
Default Re: (hitatree.at125mph)
unless you have a sohc vtec and a thermal r&d like me
Old Oct 12, 2006 | 10:03 AM
.. wha is a thermal r&d
Old Oct 12, 2006 | 05:15 PM
thermal research and developement
its the name brand very quiet exhaust
fabtoys
Mar 1, 2009 07:57 PM
bb6_00
Sep 18, 2008 07:56 PM
exotik4doorcivic
50
Oct 31, 2006 07:40 PM
crdcz03
Jan 16, 2005 03:55 PM
Gearheaded
Oct 31, 2001 11:51 AM
