Boosted b18b1........
Old Oct 13, 2006 | 12:05 PM
hushedhondacivic's Avatar
Default Boosted b18b1........
Well you see my friend...he baught a 98 hatch with a b18b swap......he wants to know if he should buy new pistons and rods first...this kid wants his car to last with boost......i told him to come on here and ask...but he refuses......so im doing it for him.....he wants to run some pretty good boost..probably more than 10 psi...i also heard that the LS can support 15 lbs safely??I dont know too much about that engine..so let me know what you guys think...sorry nothin is very specific....just something to start....thanks
Old Oct 13, 2006 | 12:24 PM
snaileg's Avatar
he should be safe without piston and rods on a ls motor on 10psi with a good tune because right now im running a stock ls on 10psi but im not tuned and its been running for about 6-7 months now
Old Oct 13, 2006 | 12:46 PM
dohcdelsol93's Avatar
Default Re: (snaileg)
tuned 10psi is safe, untuned its rolling the dice.
With fmu/missing link 5-8psi is doable but again rolling dice.
Old Oct 13, 2006 | 12:48 PM
bboysake's Avatar
12 psi is pushing it to the limit on a LS motor
Old Oct 13, 2006 | 01:45 PM
blackeg's Avatar
Default Re: (bboysake)
ls motors on a good tune love 10 psi
Old Oct 13, 2006 | 02:41 PM
Default Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">ls motors on a good tune love 10 psi</TD></TR></TABLE>
from the numbers on your sig it makes very nice #'s for any stock 4cyl. I really wanted to boost my stk ls before the engine build/LS/VTEC conversion but just wasnt didn't have the time. I really wanted a before and after comparison on the same boost level.
I'm sure with an Victor X manifold, some bigger cams and head work you could have freed up alot more HP with the same amount of boost. Maybe even come close to 300whp.
Old Oct 13, 2006 | 02:46 PM
9civichatch3's Avatar
NICE GUY
Default Re: (dohcdelsol93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 &raquo;</TD></TR><TR><TD CLASS="quote">tuned 10psi is safe, untuned its rolling the dice.
With fmu/missing link 5-8psi is doable but again rolling dice. </TD></TR></TABLE>
also the tubo size matters. 10psi on my GT28RS is a lot less air that let say a GT36R.
10psi isnt the same for every turbo
Old Oct 13, 2006 | 02:47 PM
Justin Klemgold's Avatar
You don't go by PSI...10 PSI on a little turbo will be totally different than 10 psi on a larger turbo.
You go by WHP...the LS block has been proven to be strong to 300 whp on stock internals. It can take it.
First, however, you need to get the health of that engine...do a compression test and make certain everything checks out.
Get a good EMS and find a good tuner and you'll have nothing to worry about.
EDIT: ^^^^ He beat me to it, lol.
Old Oct 13, 2006 | 02:57 PM
NICE GUY
Default Re: (Justin Klemgold)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Justin Klemgold &raquo;</TD></TR><TR><TD CLASS="quote">You don't go by PSI...10 PSI on a little turbo will be totally different than 10 psi on a larger turbo.
EDIT: ^^^^ He beat me to it, lol.</TD></TR></TABLE>
Old Oct 13, 2006 | 03:11 PM
bboysake's Avatar
Old Oct 13, 2006 | 03:18 PM
damn, you guys called me out, it's always about the CFM. to me posting while I'm painting. You have to forgive me the paint fumes get to me even with the respirator.
Old Oct 13, 2006 | 03:24 PM
oxSLEEPERxo's Avatar
yep, don't go by the psi, every turbo is different to reach a certain amount of whp
Old Oct 13, 2006 | 03:50 PM
snaileg's Avatar
ya that is very true i am running at t3/t04e very good turbo to start a project with and then as your motor build up continues then switch turbos
cristegra09
20
May 8, 2009 01:18 PM
eg6turbo143
11
Dec 7, 2006 09:22 AM
sa90eg
Jul 21, 2005 08:59 PM
Rizz
Nov 2, 2001 12:04 PM
