Problems after head swap.......
Old Oct 8, 2006 | 05:10 AM
blazin99si's Avatar
Default Problems after head swap with idle and vacuum
Recently installed a p75 head with a valve job, Crower 403s with a Crower valvetrain, stock valves and Skunk2 camgears set at 0 on my boosted B20. Anyhow, for the motor to even idle at 790rpm I had to adjust the AFC I have to -22% leaving me with a 13.7 afr. Adjusting the idle screw did nothing. However, I also noticed prior to the head swap the boost gauge was registering 17-19kg of vacuum at idle and now its at 14-15kg. Im going to be taking the car to get tuned but am a little concerned with the boost gauge readings. Any ideas/suggestions or experience with this kind of situation?
Old Oct 8, 2006 | 06:19 AM
DaveF's Avatar
Default Re: Problems after head swap with idle and vacuum (blazin99si)
you need to perform a valve adjustment on a cold engine.
also, check your cam timing/timing belt again...
Old Oct 8, 2006 | 08:56 AM
AbitAvenger's Avatar
Default Re: Problems after head swap with idle and vacuum (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote"> you need to perform a valve adjustment on a cold engine.
also, check your cam timing/timing belt again...</TD></TR></TABLE>
Old Oct 8, 2006 | 11:16 AM
drintegra's Avatar
Default Re: Problems after head swap with idle and vacuum (AbitAvenger)
the valves were adjusted and the cam gears are not adjusted. THe crank and camgears line up. THe car runs fine and the vacuum reacts like normal, ie:does not fluctuate, reacts to throttle input just as before. People say it is the cams, just need some input. THanks
Old Oct 8, 2006 | 11:20 AM
Garcia-Racing's Avatar
spread the cams out.
Old Oct 8, 2006 | 12:34 PM
93supercoupe's Avatar
Default Re: (Garcia-Racing)
the loss in vacum, is definetly the cams.
The thing will make a good amount of pwer with the right EMS.
Old Oct 8, 2006 | 04:21 PM
drintegra's Avatar
Default Re: (93supercoupe)
that is what we figure, need to get it tuned again
Old Oct 8, 2006 | 04:37 PM
blazin99si's Avatar
Thanks for all the input guys, will post again with results after tune/valve adjustment
Old Oct 8, 2006 | 05:11 PM
TurboLSVtecTeg's Avatar
Default Re: (blazin99si)
Increase your base timing at idle when you retune. You will beable to get the motor to pull more vacuum at idle and increase idle stability. Ive recently tuned some 404's on a turbo LS with 1000cc's and it took a little tuning to get the car to idle nice and steady with pulling around 18in/Hg at idle.
jreed773
Oct 16, 2012 06:14 PM
Skitso's CB7
May 20, 2011 12:20 PM
singlecamsaint
Apr 12, 2011 03:56 AM
jumpman83
Dec 12, 2008 01:02 PM
3rdGteg
Nov 1, 2002 09:31 PM
