Will this oil drain work?
Old Oct 12, 2006 | 02:37 PM
silentdaredevil2's Avatar
Default Will this oil drain work?
Please don't respond if you don't have any clue what you are talking about.
When I welded in the bung it kinda slanted downward but its not real bad at all. let me know what you think.
Old Oct 12, 2006 | 02:56 PM
BoostedEG6's Avatar
Default Re: Will this oil drain work? (silentdaredevil2)
If I where you I would get 2 45* fittings and get rid of the straights..... That should work but I would go with something else to be on the safe side
Old Oct 12, 2006 | 02:59 PM
importdude2000's Avatar
i would deinfitly use the 45's
u dont have slop
its like 90 degrees
Old Oct 12, 2006 | 03:02 PM
i was affraid of that. thanks guys.
Old Oct 12, 2006 | 04:09 PM
Bailhatch's Avatar
Default Re: (silentdaredevil2)
I would weld a male steel fitting to the pan at maybe 10-15* up and use a straight fitting there and a 45 off the turbo.
Those summit ends kinda suck too BTW. I just did about 14 of them today.
Old Oct 12, 2006 | 06:08 PM
Dunc's Avatar
BCICAN
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote"> Those summit ends kinda suck too BTW. I just did about 14 of them today. </TD></TR></TABLE>
What makes them suck in your eyes? I haven't had any problems with Summit's before.
Old Oct 13, 2006 | 11:32 AM
i already welded the pan once im not gonna take it apart and re-do it when all i have to do is buy 2 45deg fittings
Old Oct 13, 2006 | 12:03 PM
oscarmayer's Avatar
actually you only need 1 45*. the one on the bottom that connects to the pan should be 45. the other can stay straight.
Old Oct 13, 2006 | 01:18 PM
BoostedEG6's Avatar
Default Re: (oscarmayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer &raquo;</TD></TR><TR><TD CLASS="quote">actually you only need 1 45*. the one on the bottom that connects to the pan should be 45. the other can stay straight.</TD></TR></TABLE>
No look again... 1 45* on the pan will not work... it will be best with 2 45*'s
Old Oct 13, 2006 | 01:28 PM
LSVtechnologytur...'s Avatar
Default Re: (BoostedEG6)
sorry that this is a little off topic, but what oil pan gasket is that? I've seen alot of people using those blue gaskets.
Old Oct 13, 2006 | 02:27 PM
RedEj8's Avatar
Default Re: (LSVtechnologyturboboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVtechnologyturboboost &raquo;</TD></TR><TR><TD CLASS="quote">sorry that this is a little off topic, but what oil pan gasket is that? I've seen alot of people using those blue gaskets.</TD></TR></TABLE>
Silicon gasket maker?
Old Oct 13, 2006 | 03:22 PM
no, its a felpro gasket.
Old Oct 13, 2006 | 07:47 PM
Bailhatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdaredevil2 &raquo;</TD></TR><TR><TD CLASS="quote">no, its a felpro gasket.</TD></TR></TABLE>
I like those gaskets.
btw I pressurized the fuel system i made today. The summit ends tended to leak a lot more than a very similar system i built a few weeks ago with aeroquip parts. I used the same techniques in cutting and installing all the parts. I noticed the taper inside on the summit ends is more gradual and the outer sleeve has smaller less pronounced ridges. They are also in a spiral where the aeroquip ones are parallel. Next time i will make sure to pay a little more and save all the headache. $.02
Old Oct 14, 2006 | 01:04 AM
Johnyquest's Avatar
As long as that hose isn't kinked, you're fine. Drain physics. Turbo drain is higher than oil pan, it will drain. There really is no rocketry to 'em.
Matt
Old Oct 14, 2006 | 06:59 AM
yeah you are right but ive read numerous times that if it goes uphill at anytime it will not work
Old Oct 14, 2006 | 08:03 AM
Chiovnidca's Avatar
It looks fine to me.
Old Oct 14, 2006 | 08:34 AM
CBURKE's Avatar
Looks fine to me, as long as the hole is big enough it's fine. On a DSM they are just like that (A big L)
The oil is going down back into the pain, it's not like it is going to get clogged up and start making it's way up the return line. It's fine just leave it alone. Hell mine goes to the right and down and I have never have a problem. The oil is going to be HOT!!! witch makes it even more thin.
Old Oct 14, 2006 | 08:49 AM
Mykizism's Avatar
two 45's would work, probably would end up looking like my setup
Old Oct 14, 2006 | 08:54 AM
h22apwrd95's Avatar
Actually there is a great book out there on plumbing. Nuts, bolts, fasteners, and plumbing, by Carroll Smith. Talks alot about how the ends are made and what construction works the best with the hose type.
Mike
Old Oct 14, 2006 | 11:56 AM
oscarmayer's Avatar
Personally, I used a straight and then a 90* right into the pan. no issues at all it was clean and fit perfect.
Old Oct 14, 2006 | 03:06 PM
Johnyquest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silentdaredevil2 &raquo;</TD></TR><TR><TD CLASS="quote">yeah you are right but ive read numerous times that if it goes uphill at anytime it will not work </TD></TR></TABLE>
Just look under any sink in your house for proof that this is untrue
Matt
Old Oct 16, 2006 | 12:36 PM
so the final decision is that it will work?
Old Oct 16, 2006 | 12:47 PM
BoostedEG6's Avatar
Default Re: (Johnyquest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnyquest &raquo;</TD></TR><TR><TD CLASS="quote">
Matt</TD></TR></TABLE>
well that would be great if this where a sink and the only reason a sink is like that is to keep water in the trap (the U thing) when you are not running water to keep the sewer smeel out of your house...... if you look at any pipe under your house you would see that they are all going down hill.... also water is thiner than oil and drains much better
I would not use that drain like you have it now. I would do what I said before
Old Oct 16, 2006 | 12:58 PM
Johnyquest's Avatar
LOL, whatever.
As long as there are no kinks, just think kitchen sinks!
heh.
Really. It will be fine. I've tried a million ways, and i've personally found ones that didn't work. You'll know in 5 minutes, it'll just smoke to ****. You won't hurt anything in 5 minutes.
Matt
Old Oct 16, 2006 | 01:32 PM
KeyserSoze's Avatar
Yours looks a lot like mine...........
It has worked pretty well so far.
