HELP PLEASE.
Old Oct 12, 2006 | 05:51 PM
jdm2teg's Avatar
Default HELP PLEASE.
hey guys well my integra turbo stoped working 2 days ago and i need some help with it. it cranks and it has spark. but no fuel going in. to check the fuel i losened the 17 bolt on top of the fuel filter. there was no fuel coming out so i replaced the fuel pump with walbro but its still not working. when i turn the key over i dont hear the pump working.i usually hear the fuel pump working but i cant hear it. so any points can help. thanks
Modified by jdm2teg at 9:58 PM 10/12/2006
Old Oct 12, 2006 | 05:59 PM
siblues's Avatar
Default Re: HELP PLEASE. (jdm2teg)
I know its a stupid question but are you low on fuel and maybe the gauge isnt reading right?
Old Oct 12, 2006 | 06:07 PM
Brain3208's Avatar
Default Re: HELP PLEASE. (siblues)
even dumber question, have you checked ALL fuses?
My real guess would be to check the main relay. see if you can run a hot wire to the fuel pump bypassing the relay just to test it.
Brain
Old Oct 12, 2006 | 06:16 PM
siblues's Avatar
Default Re: HELP PLEASE. (Brain3208)
Good point but he said he can hear the pump when the car is on?IDK
Old Oct 12, 2006 | 06:18 PM
jdm2teg's Avatar
those are not stupid question. i would feel stupid if the low on fuel was the reason.
its little low but it has enough to stard the car.
i was thinking it might be the fuse. but i dont know which one to check. the main relay fuse? the ones under the hood?
Old Oct 12, 2006 | 07:25 PM
Brain3208's Avatar
well the post was unclear on weather he hears it or not definitively. But I would honestly check the main relay. I had a similar issue with my old car and it acted the same way. sometimes I would even hear the pump but nothing would be coming out the rail, I taped a hot to my fuel pump line and started it right up. i'd just do the same and only buy a relay if it starts. their like 60 bucks!
Good luck
Old Oct 12, 2006 | 07:36 PM
vaporboy12's Avatar
main relay would be where i start its up under the dash on the driver side above the kick panel
Old Oct 12, 2006 | 09:39 PM
jdm2teg's Avatar
Default Re: HELP PLEASE. (vaporboy12)
o k i am looking at the fuse box under the dash and notice there is 2 big black relay box. one is quite big and the other one is normal size relay box. i am guessing its the smaller size relay. how do you guys check if the relay fuse is bad? thanks for all the help guys.
Old Oct 13, 2006 | 04:19 AM
bottlefedb18c1's Avatar
I would agree on checking the fuses and relays.
And if all good see if you get power to the pump or at least to the wires under the seat when you turn the key on
Old Oct 13, 2006 | 05:13 PM
jdm2teg's Avatar
Default Re: (bottlefedb18c1)
which fuse do i check? do fuel pump has its own fuse under the dash or under the hood. also which relay fuse do i check? i looked under my dash fuse and i saw 2 black relay fuse. one is bigger than the other. so can someone point me to the right relay before i spend $60 on one. thanks and sorry for all these questions.
pappasmurf
Nov 11, 2024 07:43 AM
jthrasher1
Dec 11, 2010 12:45 PM
jdmoutkast
Jul 7, 2007 12:21 AM
eg6T
Jun 9, 2006 02:42 AM
Z6REX-SI
10
Mar 9, 2004 07:50 AM
