increasing the PSI (F22B1 T3/T04e)
Hi fellow HT. I just bought a 94 accord with an F22B1 T3/T04e turbo. Question is, when I got the car, It was set to 8 psi. I wanna push around 12-14 PSIs on stock internals. What exactly do i need to do besides get a higher psi wastegate spring and up the boost on the boost controller? BTW i'm running neptune as the tuning program but no nothing about tuning, wat can i do?
Re: increasing the PSI (boostedf22cd5)
If you already have a boost controller you won't need a new wastegate spring to increase the boost, you can just turn the dial on the controller. That being said, you will need to retune your ecu for the added boost and I think you're going to need a MAP sensor and possibly new injectors too. What injectors are you running right now? Do you know anyone in your area that tunes hondas?
