(walbro 255) fuel pump VS inline pump (areomotive,paxton,etc..)
im wounder what would be the difference of using either???
don't they both do the samething???
the fuel pump you gotta take out the back seat and remove stuff
inline you can just hook to the fuel line before the engine
some can be more expesive but the just about the same
thanks i allways woundered this
Re: (walbro 255) fuel pump VS inline pump (Smokeeey420)
Inlines like those are made to be used with a sump. There are inline pumps that add pressure but don't add the high volumes like you would want but are used with a intank pump also.
Re: (walbro 255) fuel pump VS inline pump (nsxmatt)
Correct, and sumped systems are not cheap... i wouldnt worry about it unless you are trying to make some larger HP goals, a 255LPH will do fine for most systems
