Walbro 255lph users, I have a Q??
For all you guys using a Walbro 255lph fuel pump, what did the pump raise your puel pressure to? What fpr did you use to get it back down to where it should be?
I jsut ordered one from import auto parts along with my new injectors. they should be here by wednesday which is perfect because I will be heading to the track on friday. I have a grudge match with my father. My ls-t vs his 99 c5.
Thanks guys
Thanks guys
Re: (99B16Si)
I purchased the plane jane 255lph pump, will my fp be raised much on the stock fpr? I have heard some horror stories about people not being able to get there fp back into a reasonable spec. I will be using rc 750cc injectors.
Re: (swapped95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swapped95 »</TD></TR><TR><TD CLASS="quote">what brand of fuel pressure gauge do yall use? do they all mount on the fuel filter housing??? just a few questions...</TD></TR></TABLE>
i disagree. aeromotive is the only way to go.
Re: (mike93eh2)
i just installed that pump, i have not checked the fuel pressure since then, but my car runs fine.
if people had problems with not being able to lower there fuel pressure it is due to a restriction in there return line/fpr. i cant imagine the stock setup cant handle any excess return unless the supply is overly large.
Re: Walbro 255lph users, I have a Q?? (KRWTEK1)
Thanks for all the input guys, i also think i should be fine. I will double check the fp after the pump is installed. I will let you guys know what the results are.
95gsrEG
10-19-2016 06:49 PM
FourthGenHatch
10
02-29-2004 07:35 AM
