Bigger fuel line is it worth it???
Is it worth running a bigger steel braided line off the sending unit will it free some flow or more power? Would there be a big pressure loss with a bigger line?
Re: Bigger fuel line is it worth it??? (fourdoorturbo)
If your motor is tuned to a specific A/F and it is achieving it's fuel needs properly there is no benefit to it. If you have properly sized injectors, fuel filter & fuel pump and your motor leans out at a specific HP level no matter what, then you might need to upgrade to bigger lines.
vr6chris
11-05-2005 05:30 AM
turbo Si
03-16-2003 10:28 AM
