gm map sensor hook up
Old Oct 8, 2006 | 01:50 PM
aldong's Avatar
Default gm map sensor hook up
can anyone tell me how to wire up a gm map sensor so i can run boost and will a gm map senspr work off a chevy cavilair?
Old Oct 8, 2006 | 02:13 PM
bb_one's Avatar
Default Re: gm map sensor hook up (aldong)
If you are using the GM 3 bar map sensor, it goes as follows:
Looking at the connector, with the locking pin on top, The left pin is "C", middle is "B", and right is "A".
A- Map sensor 5V input
B- Map sensor signal output
C- Map sensor ground
On my OBD1 prelude, Blu/Wht (ground), Red/Wht (5V power), & Wht/Blu (Map Sensor signal) from the map sensor connector. If going from the ECU, then D21 is ground, D19 is Map 5V power, & D17 is Map signal.
Old Oct 8, 2006 | 06:15 PM
boostedcivicsir's Avatar
Mr. Badwrench
http://www.hondata.com/tech3barmap.html
journeyquest
Jul 23, 2014 02:58 AM
methos713
Jun 11, 2007 12:43 PM
zman
Jun 15, 2006 07:40 PM
