arp headstuds
Old Oct 13, 2006 | 08:24 AM
97gsrki's Avatar
Default arp headstuds
Was wondering how many times i can reuse my arp headstuds? I have had the head of 3 times in the past and my headgasket is leaking so i need to pull it again. Just wanted to be sure that they are ok to use for a fourth time. Thanks
Old Oct 13, 2006 | 11:00 AM
B18C Turbo's Avatar
Default Re: arp headstuds (97gsrki)
I always thought they were good for about 3 cycles. I bet you $10 they will be just fine if you use them again. Im just curious as to why your headgasket is leaking?
Old Oct 13, 2006 | 11:13 AM
dohcdelsol93's Avatar
Default Re: arp headstuds (B18C Turbo)
I'd definatly check the decking on that block and have the head checked out if you keep going through head gaskets. I'd also double check the torque sequence and specs your using to hold her down.
Old Oct 13, 2006 | 11:25 AM
97gsrki's Avatar
hey thanks for the replys. I am just goin to use them again. The first time the studs were used the motor was set up for all motor. then i went to turbo and my car caught on fire so the motor came apart again. now the head gasket is leaking. it sucks because i did have the block and head check after the fire to make sure nothing was warped, thats why i pulled it apart, and everything was fine. so i dont know. but it is definetly not the dist. or vtec solnoid. so we will just have to saee what happens.
Old Oct 13, 2006 | 11:27 AM
97gsrki's Avatar
Default Re: (97gsrki)
and also, since i have an "ls vtec" stup i was told to put some hondabond around the oil gallys on both sides of the gasket. does anyone have an opinion on this? Thats how i have the motor right now and i want a few opinions as to whether or not its right.
Old Oct 13, 2006 | 12:33 PM
I have an ls/vtec and I never heard that. I'm running the Golden Eagle ls/vtec conversion kit with the OEM GSR head gasket that came with the kit. I just bolted her on with the ARP head studs to the manufactures spec and been boosting 13.6lbs ever since.
Old Oct 13, 2006 | 12:38 PM
97gsrki's Avatar
take this for what it is but my friednd who told me to put the hondabond on the hg said that it was told to him by josh at endyn, but whether or not thats true i dont know. i will jsut call them tomorrow and find out what they think. i just hate f*in oil leaks. especially when this one costs 100 to fix. damn cometic headgaskets
Old Oct 13, 2006 | 12:42 PM
I build mine a year ago so when I was doing all my research I may have forgotten anything about it and who knows maybe it also has somehting to do with the dowel pins that come with the GE kit. If Endyn recomends it I'd say it's a safe bet to trust them but being that I haven't heard it before and I researched for a year before my build I'd call just to double check or go through the archives here on HT. Whatever it is I hope you get it taken care of. It's alot of work to pull the head on our hondas.
1SlowSi
Dec 14, 2008 06:08 PM
hiphop23j
Aug 10, 2008 03:14 PM
G2Crash
Jun 13, 2004 02:56 AM
staticrex
Jan 23, 2004 01:39 PM
MisterB
Mar 7, 2002 11:31 PM
