is fuel pressure regulator necessary?
Old Oct 10, 2006 | 03:02 AM
siblue_gzer's Avatar
Default is fuel pressure regulator necessary?
a shop said i needed an aftermarket fuel pressure regulator so he can tune my car. i have a garrett t3/t4 turbo kit. i got everything except that..and he wants me to get it before he tunes, and also said something about my check valves. i'm only gonna boost around 8 psi.
Old Oct 10, 2006 | 08:37 AM
komat's Avatar
Default Re: is fuel pressure regulator necessary? (siblue_gzer)
its not needed
Old Oct 10, 2006 | 08:44 AM
85's Avatar
85
Default Re: is fuel pressure regulator necessary? (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">its not needed
Old Oct 11, 2006 | 01:57 AM
Default Re: is fuel pressure regulator necessary? (hks85)
but i have a walbro 255 lph though. will a stock one be just fine?
Old Oct 11, 2006 | 07:38 AM
Jay_Sensing's Avatar
A Walbro 255 is a fuel pump, unless you are worried about the 255 over running the stock regulator. I ran a stock regulator on mine forever with a 255 and had no problems. The only reason I put an aftermarket one on was when I was going for bigger numbers and needed to raise my rail pressure to get more fuel flow.
From the sounds of it, if he is wanting a regulator and talking of check valves, he is trying to give you a dynosaur FMU setup. Find another tuner and get your car chipped and actually tuned instead of the crap he is trying to sell you. the car will run like stock and be healthy unlike what it will do with an FMU setup where it will be stressing out the injectors and slowly killing itself.
Niskyspy
Mar 4, 2006 03:30 PM
Hawaii Da9
Jan 24, 2006 12:29 PM
oxSLEEPERxo
Dec 27, 2005 07:01 AM
gsrboost
Mar 7, 2005 12:24 PM
djnikko
Dec 7, 2003 10:42 AM
