not going into gear
Old Feb 17, 2007 | 08:55 PM
26street510's Avatar
Default not going into gear
hey fellaz. i've done a search and it is temperarly out of service. lease thats what my computer says. but anyways i was driving today and my tranny was making a chatering noise. like it was dragging some kind of metal under car. all of a sudden the shifter poped out of 2nd and it would no longer go into gear. we coasted the car to the side while it still made the chattering noise. it did this b4 when i first swaped my motor in there (d16z6) and it was an axle that poped out becuase my cusin didnt push it in far enough. this dont look like the same problem because the shifter would not go into any gear except 3rd and 4th. we put a 6puck clutch in there 3days ago. and i hav a greddy kit in there. im going to take the tranny out tomorow and take a look. any feedback and advice would be apriciated thank you.
Old Feb 17, 2007 | 08:57 PM
BoostedEG6's Avatar
Default Re: not going into gear (26street510)
check the trans fluid
my car did the same type of thing and it was low on fluid
Old Feb 17, 2007 | 08:59 PM
pchris52's Avatar
sounds like you broke the fork in the tranny an the synchro is shot... sorta sounds like metal bouncing in the tranny i bet there is even metal in the tranny fluid or the tranny fluid looks like diamond flakes.
Old Feb 17, 2007 | 09:10 PM
Default Re: not going into gear (pchris52)
yea i hope not. but the moment of truth will definitly be tomorow. the tranny fluid was the first thing that came to mind when this happened. im hoping its not to serious. but i hav a spare tranny anyways.
Old Feb 19, 2007 | 12:45 AM
pchris metal was indeed in the tranny. the fork was'nt the problem. we took the tranny apart and it was my 1st gear. jthe theet was all ripped off in chunks.. there was a leak in the tranny and the tranny fluid came out. weird, i think my other helper forgot to thightn it. just finish putting my extra tranny in there and its running the road again. but im gunna change the tranny fluid tommorow. should i get anything in perticular?
Old Feb 19, 2007 | 06:14 AM
shortyz21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 26street510 &raquo;</TD></TR><TR><TD CLASS="quote">pchris metal was indeed in the tranny. the fork was'nt the problem. we took the tranny apart and it was my 1st gear. jthe theet was all ripped off in chunks.. there was a leak in the tranny and the tranny fluid came out. weird, i think my other helper forgot to thightn it. just finish putting my extra tranny in there and its running the road again. but im gunna change the tranny fluid tommorow. should i get anything in perticular?</TD></TR></TABLE>
o dam..
Old Feb 19, 2007 | 07:05 AM
b18sihatch's Avatar
maybe your TOBis shot?
Old Feb 19, 2007 | 10:15 AM
the d16y7 tranny did not feel as responsive as the z6 tranny. but at lease the car is running now. but i got a quike question. when puting tranny fluid do i put it in the tranny till i start to see it over flow? i've never done this b4.
Old Feb 19, 2007 | 12:42 PM
I Have an STD's Avatar
wrenchin'
Default Re: (26street510)
put it in through the fill plug till it starts to come out. or you can do it through the VSS and just put the specified amount in. 1.9 quarts IIRC correct me if im wrong, i always just put two in
Old Feb 19, 2007 | 09:46 PM
Default Re: (I Have an STD)
thanks bro. this motor just has to much problemo. now theres a overheating problem only when the car is not moving in a freeway traffic. i think its my dang fans. cause once traffic cleared and the car got moving it ran fine. hope not hg.
Eric Charette
Transmission & Drivetrain
Mar 16, 2013 08:50 PM
Dkober101
Mar 5, 2008 02:34 PM
markv
Oct 25, 2003 03:40 PM
95gsr
Jul 17, 2003 04:28 AM
