Stock b18c5 how much boost?
Old Feb 20, 2007 | 08:00 PM
hayabusa750's Avatar
Default Stock b18c5 how much boost?
Stock b18c5 how much boost? If I put a turbo on it how much boost can be run on it given its stock and running the high compression it has? Thanks
Old Feb 20, 2007 | 08:05 PM
1Quikgsr's Avatar
about 7-12psi and 260-350whp
Old Feb 20, 2007 | 09:36 PM
yaaj1320's Avatar
Default Re: (1Quikgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Quikgsr &raquo;</TD></TR><TR><TD CLASS="quote">about 7-12psi and 260-350whp </TD></TR></TABLE>
forget that...but a inlinepro head gasket and boost the heck outta it...500+whp..!
Old Feb 21, 2007 | 02:46 AM
Finland's Avatar
mine made 295whp on a mustang dyno. Lasted about 4 years (40K miles), then a couple of ringlands finally popped. I'm pretty impressed that it lasted that long.
Old Feb 21, 2007 | 06:30 AM
dannydos's Avatar
Default Re: (Mr. Helsinki)
i know with the ls block....you can't(shouldn't) push more then 300hp......some guys are making around 350ish hp on about 10-12psi with itr and gsr blocks
Modified by dannydos at 10:42 AM 2/21/2007
Old Feb 21, 2007 | 06:39 AM
Schister66's Avatar
Man U FTW
made 275whp on stock....shooting for 330+whp this spring
Old Feb 21, 2007 | 06:47 AM
JoePSI's Avatar
Default Re: (Schister66)
The most I would go is 12psi, but thats pushing it. A conservative boost level would be 8psi. I personally would go 10 psi, should net right under 300hp on a dynojet.
Old Feb 21, 2007 | 09:21 AM
Schister66's Avatar
Man U FTW
Default Re: (JoePSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoePSI &raquo;</TD></TR><TR><TD CLASS="quote">The most I would go is 12psi, but thats pushing it. A conservative boost level would be 8psi. I personally would go 10 psi, should net right under 300hp on a dynojet.</TD></TR></TABLE>
what turbo are you basing that on?? 10psi will make 300whp is a pretty broad statement....it really depends on the turbo you're using. To the OP, what is your setup?
Old Feb 21, 2007 | 09:24 AM
JoePSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">
what turbo are you basing that on?? 10psi will make 300whp is a pretty broad statement....it really depends on the turbo you're using. To the OP, what is your setup?</TD></TR></TABLE>
You're right it is a broad statement.
I said right under 300, which I would say around 280hp to be more exact.
I based this off of my old build which used the most common turbo IMO. the t3/t4oe 57trim.
Old Feb 21, 2007 | 12:39 PM
D16SohcVtec's Avatar
Default Re: Stock b18c5 how much boost? (hayabusa750)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa750 &raquo;</TD></TR><TR><TD CLASS="quote">Stock b18c5 how much boost? If I put a turbo on it how much boost can be run on it given its stock and running the high compression it has? Thanks</TD></TR></TABLE>
As long as it's perfectly tuned by someone who knows what they doing I don't see why 10 psi isn't possible. With all the new technology out there like Crome, Hondata, Neptune etc. High compression guys can also enjoy boost.
Old Feb 21, 2007 | 12:49 PM
JoePSI's Avatar
Default Re: Stock b18c5 how much boost? (D16SohcVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16SohcVtec &raquo;</TD></TR><TR><TD CLASS="quote">
As long as it's perfectly tuned by someone who knows what they doing I don't see why 10 psi isn't possible. With all the new technology out there like Crome, Hondata, Neptune etc. High compression guys can also enjoy boost. </TD></TR></TABLE>
So true, the tune is so vital to the longevity of your engine. I would say it is the key thing to keeping an engine running.
...my 9.7:1 pistons should come in today!
Old Feb 21, 2007 | 02:07 PM
RedR's Avatar
stock itr here though i got a thicker hg, pushing 10 psi on a t3/t04 for over a year and not a single problem.
Old Feb 21, 2007 | 03:25 PM
dannydos's Avatar
Default Re: Stock b18c5 how much boost? (JoePSI)
http://video.yahoo.com/video/p...turbo
i dont remeber if it was stock or not...but i think it was at 14psi...i could be wrong....
JUANSTURBOTEG
May 18, 2007 06:43 PM
broadheadjohn
Apr 15, 2007 11:48 AM
ras
May 3, 2005 09:14 AM
slo_crx
Oct 6, 2004 08:31 AM
mozez
Jan 13, 2004 08:48 PM
