dart block turbo
Old Feb 15, 2007 | 07:45 PM
saintspall's Avatar
Default dart block turbo
Anyone using 85x95 engine turbo?will the crank be too big
Old Feb 15, 2007 | 08:04 PM
NJIN BUILDR's Avatar
Default Re: dart block turbo (saintspall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saintspall &raquo;</TD></TR><TR><TD CLASS="quote">Anyone using 85x95 engine turbo?will the crank be too big</TD></TR></TABLE>
Cranks fine,bores to big.Start with 84mm.
Old Feb 15, 2007 | 10:24 PM
saintspall's Avatar
Default Re: dart block turbo (NJIN BUILDR)
Can the eagle light weight crank handle boost?i'm at 85mm na now,just thought of changin piston and go boost.
Old Feb 16, 2007 | 04:34 AM
Crank should be fine.It's just harder to seal a head gasket with the 85mm bore,although lots of people have done it successfully.
Old Feb 16, 2007 | 04:48 PM
saintspall's Avatar
oh ok maybe i can get it resleeve.
Old Feb 28, 2007 | 11:24 AM
jimjam187's Avatar
iVE GOT DART BLOC THAT 85W 95 MM STROKE i USED THE CROWER KIT
Old Feb 28, 2007 | 12:46 PM
hybridmoments's Avatar
wow. resleeve. that is some $$$ . if anything just get the cylinders o-ringed. should be ok.
Old Feb 28, 2007 | 06:02 PM
Semnos's Avatar
Default Re: dart block turbo (hybridmoments)
It's a dart block..resleeve should be relatively cheap..its a liner.
There a more 85mm bore boosted engines out there then some of you think.
Old Feb 28, 2007 | 06:29 PM
THEDirtyDseriesWOOT's Avatar
they do make 85mm head gaskets.. cometic does atleast it will seal just get the right size.. if ur still scared oring that bad boy
Old Mar 1, 2007 | 04:56 AM
fast93accord's Avatar
thats what my motor is. 85.5mm bore, 95mm stroke. Its a torque monster...
Old Mar 1, 2007 | 06:41 AM
Muckman's Avatar
Moderator in Chief
Default Re: dart block turbo (fast93accord)
O-ringed?
nemesis.442
17
May 7, 2012 12:34 PM
teddy_dc2
Aug 8, 2007 06:37 PM
cltitus
Feb 12, 2007 07:45 AM
d16dcoe45
Oct 25, 2006 03:52 PM
4piston
Oct 31, 2005 04:57 AM
