shaving head and compression increase?
Old Feb 17, 2007 | 02:04 PM
melovesboost's Avatar
Default shaving head and compression increase?
I wanna know what the actual compression increases are with shaving a head.
EX.. shaving 0.010" = .2 Compression increase
that was just a example not sure on the actual numbers.
Dose anyone know the actual figures for this?
Old Feb 17, 2007 | 03:42 PM
rmcdaniels's Avatar
Default Re: shaving head and compression increase? (melovesboost)
http://www.c-speedracing.com/h...c.php
You can do the math ( amount-milled x pi x radiud x radius ) to figure out how much chamber volume is lost, or just subtract the numbers you mill it from the stock head gasket thickness in the program to get the same result.
Old Feb 17, 2007 | 09:13 PM
broketuner-Sol_Si's Avatar
Default Re: shaving head and compression increase? (rmcdaniels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">http://www.c-speedracing.com/h...c.php
You can do the math ( amount-milled x pi x radiud x radius ) to figure out how much chamber volume is lost, or just subtract the numbers you mill it from the stock head gasket thickness in the program to get the same result.</TD></TR></TABLE>
I was always under te impression that comp. calculator wasn't very accurate.
Old Feb 18, 2007 | 12:14 AM
ya i heard that as well. thats why i dont rely on a compression calculator. hoping some reliable engine builders could put there input in on this
Old Feb 18, 2007 | 07:27 AM
.dave's Avatar
i HAS questions ?
Default Re: (melovesboost)
Your bore size, combustion chamber volume, headgasket thickness, and valve dish size are going to affect this as well. Is everything on the head stock (in terms of combustion chamber, etc) or has it been modified?
Think about it this way. The swept volume by the piston is going to remain the same. That is one factor of the compression ratio. The rest is determined by the factors involving the head. Numbers exist for the stock head combustion chamber volume, so if you do a little research and bust out a basic calculator or even a slide rule you should easily be able to compute this.
ProjectBB6
Mar 13, 2008 09:24 AM
Ivan_JDM_hatch
12
Jul 13, 2007 06:44 PM
allmotorbeasteg6
Aug 25, 2004 12:19 PM
prdtr15
Sep 25, 2003 03:45 PM
