Hall effect setup, ideas, help
Old Feb 14, 2007 | 08:25 PM
TEGNO1's Avatar
Default Hall effect setup, ideas, help
Hi i just bought an SM4 and am considering removing dizzy and converting to hall effect setup.
I am using toda cam gears and would like to keep them.
Anyone got any ideas about the best way to set it up,
I know of the existing setup tony1 etc, but i would like to keep my toda gears and power steering.
One idea i had is going off the back of the cam were the dizzy mounts but remove or modify the internals of the dizzy to hall effect setup.
thanks in advance.
Old Feb 14, 2007 | 08:33 PM
siblues's Avatar
Default Re: Hall effect setup, ideas, help (TEGNO1)
Well as far as the kit goes I know you can keep power steering but I am not sure about the gears.I remember Tony stating the golden eagle gears are the only ones with enough room for the magnets?
Old Feb 14, 2007 | 09:03 PM
TEGNO1's Avatar
Yeah i had a look and i dont think the todas have enough room, maybe there is another way, thanks.
Old Feb 14, 2007 | 09:09 PM
.dave's Avatar
i HAS questions ?
Default Re: (TEGNO1)
They're cam gears, is it really that big of a deal?
Old Feb 14, 2007 | 09:15 PM
morgan@synapse motorsport's Avatar
Default Re: (.dave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .dave &raquo;</TD></TR><TR><TD CLASS="quote">They're cam gears, is it really that big of a deal? </TD></TR></TABLE>
x2
and the t1 cam trigger does not have to remove power steering.
Old Feb 14, 2007 | 10:59 PM
TEGNO1's Avatar
Ok thanks for clearing the power steering thing up, so far it looks like tony1 kit if i can get one, sell my todas and by golden eagles,
Any other ideas thanks in advance.
Old Feb 16, 2007 | 11:19 PM
TEGNO1's Avatar
What about the MSD pro billet thats a hall effect setup isnt it.
Old Feb 17, 2007 | 05:59 AM
rmcdaniels's Avatar
If you want to remove the distributor, then you'll need a 4-channel ECU. What EMS are you using?
Old Feb 17, 2007 | 06:11 AM
tony1's Avatar
The SM4 has 4 ign outputs, so with my trigger and a multi channel ignition box, you can completely remove the dist.
Old Feb 17, 2007 | 06:25 AM
rmcdaniels's Avatar
Default Re: Hall effect setup, ideas, help (tony1)
Doh! Reading&gt;Me. I don't have any experience with the MSD distributor, but I've been using Tony's Hall Effect setup with an AEM EMS for a while and it is pretty amazing. The timing signal is rock steady and the waveform is perfect (I checked it with an oscilloscope), idle is perfectly even and smooth (even down to 500-600 RPM), and no misfires under any conditions.
Old Feb 17, 2007 | 06:53 PM
TEGNO1's Avatar
I have got an MSD dis4 for ignition, how much is the T1 setup including 2 cam gears.
Also the power steering kit again, the bracket on the T1 kit that bolts up to mount the sensor uses the same 2 bolts that my power steering pump uses, so would the power steering bracket have to sit on top of the T1 bracket, anyone got any pics with power steering and T1 kit.
And regarding the MSD pro billet can anyone tell me if this is a true hall effect setup and would it work with my setup,
thanks.
Old Feb 17, 2007 | 06:58 PM
siblues's Avatar
The Tony1 setup will work with the power steering all you have to do ias mount the bracket first then put the powersteering bracket on top of it and get longer bolts.I just asked Tony that a few days ago.The msd is a true hall effect setup.
Old Feb 17, 2007 | 07:30 PM
TEGNO1's Avatar
Thanks the info that was what i was after,
So if your were to install the MSD dizzy, you could use the hall effect for your triggering located inside the MSD dizzy, instead of the standard magnetic sensor inside the standadard dizzy, but plug in the ignition box and coils as normal (from SM4 to DIS4 to coil pack) by passing the rotor and single coil setup of the MSD dizzy,
thanks again.
Old Feb 17, 2007 | 07:49 PM
rmcdaniels's Avatar
You could do that, but why pay the $ to hack up an MSD distributor when you can get a better (by better I mean more precise due to the diameter of the ring of magnets on the cam gear as opposed to the distributor) signal from the Tony1 setup?
Old Feb 17, 2007 | 07:56 PM
TEGNO1's Avatar
You wouldnt hack it up just connect the dizzy trigger plug to the trigger input of the SM4, and thats about it.
I'll have weight up my options considering price, performance, and ease of installation.
thanks.
Old Feb 17, 2007 | 08:01 PM
rmcdaniels's Avatar
But wouldn't the trigger signal be conditioned into a sine wave if it's made to plug into a stock ECU? I haven't taken an oscilloscope to one yet, but I'd think that you'd have to open it up and find the output of the Hall Effect sensor/s and wire that to your SM4 if you wanted to get a true digital signal.
Old Feb 17, 2007 | 08:32 PM
TEGNO1's Avatar
Thats too technical for me, id like to find out though as that defeats the purpose really, i definately dont think its worth taking apart, but on the other hand if it does give you straight access to the hall effect sensor, that would be good then i could just plug it in,
But how can you be sure, ill try and give MSD an email, thanks.
LvN
44
Dec 3, 2009 03:16 PM
BlueTeg01
31
Oct 21, 2004 09:18 AM
Edw-R
Sep 11, 2004 11:19 PM
Edw-R
Sep 11, 2004 11:07 AM
jdmb18c
Nov 19, 2002 06:15 PM
