COOLANT for Turbo - Single Looped Line? One Source OK?
I want a CRX tattoed on my butt
Hey guys
I am planning on making an addition to my factory waterneck (d16) and basically just extending out the water neck form the head about an inch so I can drill and tap a water temp port. With that space I also plan to drill and tap a hole to watercool my turbo
I was hoping I could simply drill and tap one hole for the turbo, have a single line coming off off the head, split at the turbo and each line (from the same source) go to a port on the turbo
Would this work fine? Would this flow?
Thanks
Thanks
Re: COOLANT for Turbo - Single Looped Line? One Source OK? (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">it wont flow.</TD></TR></TABLE>
Yep..not going to work.
Re: COOLANT for Turbo - Single Looped Line? One Source OK? (PINKS)
you need presure for flow, you need one line before the waterpump and another after. that way you have a feed and return
Re: COOLANT for Turbo - Single Looped Line? One Source OK? (prelittlelude)
So if I use one coming off of the waterneck on the head, where would a good source for my other one be
Re: (Got_soy)
Where does that sucker lead to? behind the coolant jacket?
Im assuming you mean the plug on the left side of the block about 1/2 way down?
Re: (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS »</TD></TR><TR><TD CLASS="quote">Does that threaded plug on the front of the block go to your coolant jackets though?</TD></TR></TABLE>
yes it is the drain plug for the block.
Re: (mike93eh2)
Wouldnt happen to know the size and pitch off hand woulda ya Mike?
No danger on running a clamped hose from the turbo to a barbed fitting there?
Re: (PINKS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS »</TD></TR><TR><TD CLASS="quote">Wouldnt happen to know the size and pitch off hand woulda ya Mike?
No danger on running a clamped hose from the turbo to a barbed fitting there?</TD></TR></TABLE>
no i dont... and no danger in it.
but i still think it is alot easier to run it inline with the IACV.
