has anyone used a gt3076R .82ar hotside on a d-series
heres the story this is going to be a drag only car no street time on this baby
i ordered the gt3076R with .63AR hotside they sent me the .82ar do you think i should use it or just go ahead and return it for a 63.. how long do you think till it spools.. we plan on spraying to spool up later on this year anyways soo what do you guys think
everyone on turbo d16 is anti 82ar.. but none of them have any real experience with it.. anyone.. even a b16 so i can find similar spool
setup as follows
sleeved d16z6
cp 9:1
eagle rods
acl bearings
toga hv oil pump
head::
stock port job
stock valves .. For now will change soon
zex springs and ret
zex59300 cam
venom intake mani
Rc 750s
hondata s300
precision 600 hp ic
sls topmount
4"dp
and gt3076R .82AR
thats basically the gist of it alot of other things left out.. so how do you think it will perform garret tech said .63 will make 450 and thats about the limit i wanna make 500 just trying to get into the 10's so what you guys think
setup as follows
sleeved d16z6
cp 9:1
eagle rods
acl bearings
toga hv oil pump
head::
stock port job
zex springs and ret
zex59300 cam
venom intake mani
Rc 750s
hondata s300
precision 600 hp ic
sls topmount
4"dp
and gt3076R .82AR
If its a drag car like you said, I'd try it. The turbo has proven to do well on other d16 setups. Just be prepared to wait a touch more for the initial spool. I think if your head was ported, the .82 ar would be even better to take advantage of a longer power band.
Re: (ELSpool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ELSpool »</TD></TR><TR><TD CLASS="quote">If its a drag car like you said, I'd try it. The turbo has proven to do well on other d16 setups. Just be prepared to wait a touch more for the initial spool. I think if your head was ported, the .82 ar would be even better to take advantage of a longer power band.</TD></TR></TABLE>
yah thats what im thinking.. how big a diff is the 82 ar gonna make on spool time.. i do plan on getting a port job and oversized valves soon prob tune it without make a few trips to the track and port it then slap n20 on it
its a drag CAR... no street time
im looking for somone who has done it before..
and a 3076R with a .63 is not big.. u get full boost by 5000 rpm on a d with it...
anyone with experience
Re: (rota92)
thats what i was saying, go look at turbod16 and search for the members that have used the bigger turbo's. most of them havn't had much success at all with anything over a 57 trim, and even with a gt series turbo if you are not ft shifting you will almost certainly fall out of boost between shifts. the one person i know of having great results with a bigger turbo is a guy using a gt30 with a .63 a/r, and he is making 500whp with it effectively. all others that have tried are running into problems at about the 400whp mark. if it is an all out drag car then you can go for it, but for the best aviliable power band why not get something smaller like a 57 trim or a gt30 .63 a/r. even though it is drag racing, the car with the most hp will not always win. powerband plays a big role in track times.
castranda7408
01-28-2013 04:03 PM
em1effekt
11
08-18-2010 09:21 PM
