whats the advantage of using an external vs internal wastegate
Re: whats the advantage of using an external vs internal wastegate (b16a4)
Power wise none really, but most large turbos do not have internal gates.
If you want to keep things quite a internal gate will do that, but so will a closed loop external dump too.
In general it doesn't matter.
Re: (turbotegy)
So if i was putting together a kit for my d series on the cheap, it would be best to go for a turbo that is internally gated?
What benifits are there by switching to an external gate?
What limitations are present sticking with an internal wastegate?
