van line sizes
Old Feb 21, 2007 | 03:58 PM
aryiman98civic's Avatar
Default vac line sizes
hey honda-tech i am here at school and i will be finishing up my turbo in two days. tomorrow i am going out to get the rest of my parts and i need two vac lines, one for my 38 mm tial wastegate and one for my turbo xs rfl bov. i dont know the size of lines i need for these two items so if someone could help that would be great. thanks
Old Feb 21, 2007 | 04:26 PM
HiProfile's Avatar
Default Re: vac line sizes (aryiman98civic)
Get whatever size is used for the included nipples. IIRC 1/4" is about what you see on either. As long as 26 in/Hg of vacuum won't collapse the hose, bigger is better. Its also a very good idea to hook them up to the same spot on the manifold. I use a 6-port distibution block fed by the intake-to-brake booster line.
Old Feb 22, 2007 | 06:02 AM
Default Re: vac line sizes (HiProfile)
here is what the fittings look like. i need a size for the one on top of the bov and for one of the fittings to the left of the wastegate.
Old Feb 22, 2007 | 10:13 AM
dpetro1's Avatar
wg is gonna be 1/4" (6mm). other accessories should be the same (bov, map, boost controller, etc.). boost gauge might be 1/8" (4mm). and i think my profec b uses a 1/8" for the display.
Smashback
Mar 12, 2013 02:31 PM
geezer_187
May 8, 2006 04:18 PM
anguish
Jun 7, 2004 06:54 PM
BodyKits NW
Sep 17, 2003 10:56 PM
echo999
May 1, 2002 08:12 AM
