3" downpipe to a 2.25" stock exhaust pipe? disadvantages?
im thinking about running a 3" downpipe straight to a 2.25" stock exhaust pipe. i know im going to increase the backpressure but this is just for daily driving and on the highway. i dont really care about power. i just want to keep it as quite as possible. so my question is, is this going to be hard on my turbo or any seals running the 3" pipe to the 2.25" pipe? when i go the track every few weeks ill just take off the stock exhaust and run an open pipe. thanks
Re: 3" downpipe to a 2.25" stock exhaust pipe? disadvantages? (doood)
there are plenty of cars that aren't loud with a 3" exhaust. even my car with an N1 style muffler with the baffle on it is super quiet. i have a resonator which helps with the sound a lot. i wouldn't use the stock exhaust... period.
Re: 3" downpipe to a 2.25" stock exhaust pipe? disadvantages? (TypeSLO)
my old car was loud with a 2.5" exhaust. can any harm to my engine be done?
If noise is what you are worried about you can run 2 straight through ultra flows and the car will be super quiet. Run one where the cat would go and the other where the normal muffler would be.
your increasing exhaust pressure everywhere which is not a good thing. you will need a retune which will smooth out the higher egt's your going to have from so much backpressure.
why not run a 2.5" muffler like an oem rsx or s2000?
Re: 3" downpipe to a 2.25" stock exhaust pipe? disadvantages? (the.hamburglar)
you can run larger resonator, high flow cat, larger muffler. you can get resonators and muffler to be straight through and not loose power.. first of all, how much power are you making? you can only go so far with 2.25 stock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar »</TD></TR><TR><TD CLASS="quote">hoping for 250 at the wheels</TD></TR></TABLE>
you can do that if you want. wont hurt much, if you run open WG you could get away with 50-75whp more with no problems.
Re: 3" downpipe to a 2.25" stock exhaust pipe? disadvantages? (ngogsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ngogsr »</TD></TR><TR><TD CLASS="quote">dangit i have stock exhaust......
460whp stoopified </TD></TR></TABLE>
ya right...
ya right...
make sure u tune the car with the muffler removed. i am running stock exhaust on my car but i have a 3" downpipe that leads to a E-cut out right under the oil pan. i have no problems ..... yet... boost n the car on the stock muffler
Re: 3" downpipe to a 2.25" stock exhaust pipe? disadvantages? (boosted k20)
I always thought the stock exhaust was 2", what models came with the larger exhaust? Anyway, 2" or 2.25" crush bent will definitly increase the back pressure, but I know how you feel about loud exhausts. What's quite to one person is loud to another.
I running a 2.5" downpipe, no cat, into a thermal 2.25" catback and I wouldn't want it any louder. I feel like I should run something bigger, its tough.
I'm also in victoria BTW
**** i didnt see that you said stock exhaust. I was thinking a straight through 2.25" which flows way more than a stock one.
litterbox
07-26-2005 04:14 PM
